help me pleaseeeeeeeeee
Dodger
6
Archived from groups: alt.sys.pc-clone.packardbell (More info?)
Hi to all u people
i need help so badly here as i have no clue where to go the story is as
follows
i got a second hand igo4000 and decided to get a bigger harddrive then i
fdisked it and made 2 partions named HDD then brought master disks from
packard bell put the disk in and all i got when trying to install was
glue error press any key witch i did then got message error 5 glue
error and just went into dos now i have no idea in how to restore it
back to its origin state from factory can anyyone help me please i am at
my wits end here
roger
Hold it... easy does it.
You put in a bigger HD. What happened to the smaller HD? Is that still in or
not?
Reading your mail postage, I get the impression that it isn't. This means:
starting all over again.
Question:
Why did you try to install the packard bell software again?
Wasn't is better to get original software, but not from Packard Hell?
You didn't mention what type of Windows you were using, but you were able to
use FDISK.EXE
This makes me think:
Did you activate the drives, after the partitioning? FDISK states that you
have to!!
And:
If you can't get the lot installed, how come you can make a posting? You are
on line!
In any case: I think it is better if you re-post your message, and slowly,
while giving details, tell what has happened, because I don't think that you
can be helped after this panic-posting....
Good luck!!
Cor
"dodger" <superman40@ntlworld.com> schreef in bericht
news:s9DGd.869$263.679@newsfe2-gui.ntli.net...
> Hi to all u people
> follows
> my wits end here
> roger
> not?
> Question:
> use FDISK.EXE
> have to!!
> And:
> on line!
> Good luck!!
> Cor
>>Hi to all u people
>>follows
>>my wits end here
>>roger
well sorry if it sounded panic well i am on another computer on line so
thats why i posted this
i took out the old hard drive to put a bigger one in anyway its now done
took it to pc world and they said it needed re tattooing so they did
it and now i can use the backup disks but thanks for replying to it even
though i sounded of my head
oh by the way am using windows xp home or will be on laptop
roger
Okidoki... Thanks. I know what you feel.. I have been there... Packard Hell
is not easy when you want to re-install.
My advice is: Try to get a copy of XP or whatever OS you want to use, and
put that on. I did, with ME, and it works better than Packard Hell.
I don't know if you can read Dutch, but here is what I had to go through,
because I also choose Packard Hell.
Perhaps someone can translate it for you. I mailed this to Packard Bell
Holland, a month ago... no response!
Aan:
De mensen van Packard Bell.
Ongeveer vier jaar geleden kocht ik een Packard Bell computer, een Iconnect.
Het nummer van deze PC was X010130100. U weet uiteraard de specificaties van
dit soort computers.
In het begin was alles prima, totdat de software begon op te spelen. Nu had
U een rode nooddiskette erbij geleverd, dus ik dacht, dat ik mezelf wel kon
helpen. Maar nee.... Tijdens de garantieperiode is mijn PC maar liefst 3
maal teruggeweest om nagekeken te worden. Gedurende die tijd zat ik dus
zinder PC, en met familie in het buitenland, afhankelijk van E-mail.
Gezellig!!!
Ik kreeg van U toegestuurd vervangings-CD-Roms van het besturingssysteem
Windows ME.
Toen liep e.e.a. wat beter, dat moet ik toegeven. Maar gaandeweg, na de
garantieperiode kwamen de problemen weer terug. Vastlopende computer, blauw
scherm, enz, enz. Hoe vaak ik Format C: heb moeten typen weet ik niet
meer.....
Uiteindelijk heb ik zelf de originele software (Windows ME) vervangen door
een originele versie van Windows 98 SE. Software-probleem verholpen. En ik
ben een leek....
Omdat Windows 98 SE minder mogelijkheden heeft dan Windows ME, heb ik na 3
jaar Windows ME weer geïnstalleerd, ditmaal vanaf 1 Cd-rom. Ook nu weer geen
problemen. Dus waarom moest ik eerst werken met 3 Cd-rom's? Of zie ik het
allemaal te simpel?
Na zo’n 4 jaar na aankoop heb ik de Cd-rom Reader/writer moeten vervangen.
O.K., dit kan slijtage zijn geweest, dat geef ik toe. Maar toch...
Omdat ik zat met een Harddisk van 20 Gb, heb ik er een harddisk bijgekocht,
ditmaal van 120 Gb. Dit speciaal voor mijn muziekverzameling. Maar goed ook,
want drie weken later begaf de 20 GB harddisk het. Niet meer aan het draaien
te krijgen. Er zat sluiting in....
Ik heb toen Windows ME geïnstalleerd op de 120 Gb harddisk, zodat ik toch
nog het een en ander kon doen.
Dit ging prima... een week lang. Toen was de hele computer niet meer te
starten. Het bleek de voeding te zijn. Nieuwe voeding er in, en weer kon ik
draaien.
De volgende dag had ik geen signaal meer op de monitor. Navraag leerde mij,
dat dit het moederbord was..... Als ik dit zou vervangen, zou deze PC
(behalve de kast) geen Packard Bell meer zijn.
Maar nu had ik er toch echt schoon genoeg van. Ik heb de bruikbare
componenten er uit gehaald, en heb een andere PC gekocht. Voor mij NOOIT
MEER een Packard Bell, Packard Hel, Pak en Bel, of wat dan ook.
Met andere woorden: Dank je wel, Packard Bell. Zo zie je maar weer, dat je
auto’s (Packard) en telefoons (Bell) niet kan mixen. Dan krijg je rotzooi.
C. van Deemter
Apeldoorn
news:jsgHd.11$cN6.4@newsfe4-gui.ntli.net...
in or
> > not?
means:
> > Question:
able to
> > use FDISK.EXE
you
> > have to!!
> > And:
are
> > on line!
slowly,
you
> > Good luck!!
> > Cor
> >>Hi to all u people
> >>follows
> >>my wits end here
> >>roger
> roger
