Help me reformat my HDD
Charles_50
69
I just "zero fill Full Erase" my hard drive today using Seagate Tools for Dos, and then i created a bootable usb using a YUMI software. And then when I boot it to my PC i cant find an option to boot it, it is just only saying GRUB4DOS, or "Minimal bash like line editing is supported and i'm stuck with that because i just permanently deleted all my files including my OS using seagate tools for dos option to full erase it. I dont know how can i put an OS to my pc now. PLEASE HELPPPPPPPPPPPPPPPPPP!
How to create an OS installation media? is it the same when creating bootable usb and you just need windows disk image (iso file) and a bootable software.
PS : I'm getting a windows 10 pro os instead
HEY luckily i successfully booted my windows 10 but it says that Load [strike]drier[/strike] Driver, it cannot identify the partition where the OS can be installed. IS MY HARD DRIE FAILING NOW OR FAULTY? CAUSE IT CANNOT DETECT AND PARTITION SO THAT THE OS CAN BE INSTALLED ON/
PPS: NEED HELP ASAP!!!
