A aroy13131 Jan 18, 2019 2 0 10 Jan 18, 2019 #1 can i run one 1600mhz and one 1866mhz ram together on my asus z97x gaming 5 motherboard
Solution scout_03 Jan 18, 2019 it is not realy good to mix ram also ram must have same jedec settings and voltages and the 1866 wont got ove 1600 in speed .
scout_03 Titan Ambassador Feb 18, 2010 30,587 324 107,640 Jan 18, 2019 Solution #2 it is not realy good to mix ram also ram must have same jedec settings and voltages and the 1866 wont got ove 1600 in speed . Upvote 0 Downvote Solution
USAFRet Titan Moderator Mar 16, 2013 179,768 22,104 184,590 Jan 18, 2019 #3 aroy13131 : can i run one 1600mhz and one 1866mhz ram together on my asus z97x gaming 5 motherboard Maybe, maybe not. Upvote 0 Downvote
CountMike Titan Oct 31, 2015 35,671 3,835 147,990 Jan 19, 2019 #4 Put the slower RAM in first slot and reset CMOS, with a bit of lack it will adjust second one to work together. Upvote 0 Downvote
N negrescualex26 Dec 24, 2018 4 0 10 Jan 19, 2019 #5 aroy13131 : can i run one 1600mhz and one 1866mhz ram together on my asus z97x gaming 5 motherboard It's not okay to mix up RAM... Upvote 0 Downvote
CountMike Titan Oct 31, 2015 35,671 3,835 147,990 Jan 19, 2019 #6 The way I described worked many times but I wouldn't recommend unless you already have those RAMs and have to buy new one, Upvote 0 Downvote
jitendrad Notable Dec 28, 2018 258 7 915 Jan 19, 2019 #7 Definitely you can attach different speed RAM in same motherboard it will work. So if you attach 1600MHz and 1800 MHz RAM in same motherboard, then 1800MHz RAM will be downclock to 1600 MHz which will effect on performance Upvote 0 Downvote
USAFRet Titan Moderator Mar 16, 2013 179,768 22,104 184,590 Jan 19, 2019 #8 jitendrad : Definitely you can attach different speed RAM in same motherboard it will work. And the hundreds of threads here where people mixed RAM type and/or speeds and it did NOT works says otherwise. Upvote 0 Downvote
