Help me to choose between theese cards ASUS GTX 660 Ti 2GB or GIGABYTE GTX 760 2GB GDDR5 OC
I've had the Asus since Christmas - quiet, quick and seems completely reliable...
nVidias own specs show a slower texture fill rate for the 760, but faster memory clock - on balance I'd probably stick with the 660ti - lower power requirements, but the case can be made either way. The Asus is a little faster than stock though.
760 - http://www.geforce.co.uk/hardware/desktop-gpus/geforce-gtx-760/specifications
660Ti - http://www.geforce.co.uk/hardware/desktop-gpus/geforce-gtx-660ti/specifications
I prefer the 660ti as well because its consumption, but there are many different opinions around theese cards, thats why i post the 2cards between i cant choose.
Both of the cards are ~320$ in my country and its not worth to order from abroad.
Then go with the 760 bro
The GTX 760 (256-bit, 192.2 GB/sec) has greater memory bandwidth than the GTX 660 Ti (192-bit, 144.2 GB/sec).
The Gigabyte GTX 760 WindForce OC runs a couple of °C cooler when under load and seems to overclock better than the ASUS GeForce GTX 660 Ti DirectCU II.
Definitely go with the GTX 760. The 660 Ti is getting old and it is not as powerful and will not give you as good framerates in the real world. If you can afford the 760, it is a no brainer.
