I am upgrading both the case and the psu on my Dell desktop.
I obtained a Corsair 650TX and a Lian Li case.
I moved the motherboard to the new case and installed the psu. Then I installed my GTX 240. I turned the system on. the CPU fan went on but nothing on the screen.
I removed the GTX 240 and plugged the monitor into the motherboards internal gpu. Nothing appeared on the screen.
How can I tell where the problem. The case came with a tiny speaker, but I don't see where plug it into motherboard.
The only things plugged into the motherboard at the moment are:
24-pin power connector from psu
4-pin pwer connector from psu
CPU fan (I never uninstalled that)
4 memory sticks (I never uninstalled them)
Help!
Help!
