HELP ME!!!! Which GPU is Suited for my comp
stiggy007
41
HEY GUYS NEED A LIL HELP!!! :hello:
Can you pls suggest me a good gaming graphic card which is within 5000Rs(INR)
My comp specs are
MotherBoard- Gigabyte M68M-S2P (Socket M2) http://www.newegg.com/Product/Product.aspx?Item=N82E16813128424R
RAM- 2GB
Proccesor- AMD 9750 Quad Core 2.4ghz
I am lookin for a card which can run games like NFS Mostwanted 2012,RUN,Driver sanfrancico and any other good games such as crysis gta4 MW series etc...!!!
I came across Sapphire AMD/ATI Radeon HD 6670 1 GB DDR3(http://www.flipkart.com/sapphire-amd-ati-radeon-hd-6670-1-gb-ddr3-graphics-card/p/itmd4f6shhvfzhum) which is well within my budget but is that card any good??
And can i know the Nvidia alternative for the above card which suits my budget!!!???
And pls do give me the names of graphic cards which is well in by budget!!!
And wats the fuss about PCI PCIE and ACP???
Which version is supported by my CPU????
Sorry for sooo many questions!!!
PLS HELP ME 😀
Regards!!!
Your mobo supports pci-e.yes under rs 5000 the best card is hd 6670 ddr3.i reccomend you raise your budget to rs 5600 and get saphhire hd 6670 ddr5.ddr5 is very fast than ddr3.
But will my mobo support hd 6670 ddr5??? cuz motherboard manual says its supports only DDR2 RAMS!!! And are RAMS AND GPU related??? And is it best to stay with Radeon or shall i go looking after Nvidia???
Thanks a lot for spending ur u precious time answering my question!!!!
