Help me with my i3 build
Adsthebest
117
help me with my gaming build
parts list
intel 3.5 GHz LGA 1150 i3-4150
ZOTAC NVIDIA GeForce GTX 970 4 GB GDDR5
Corsair DDR3 4 GB(2 x 4GB) PC RAM @ 1600 mhz each
Corsair VS550 550 Watt PSU
Asus B85M-G Motherboard
total - 823 Us dollars (currency converted)
what is your part list for the same budget ?
is my build good for gaming on ultra settings on 1080p or even 4k
Adsthebest
117
hey bro thanks for that my each corsair ram stick in the list is 1600 mhz
and will my i3 4150 cause bottleneck to gtx 970 ?
Adsthebest
117
i5 is very expensive in my country and i am on tight budget
Feb 15, 2015
438
I would get
this RAM
http://www.flipkart.com/g-skill-ripjawsx-ddr3-8-gb-2-x-...
this mobo
Asrock H97 Pro4 or Gigabyte GA-B85-D3H
Corsair is also best. It is in cheap price than Gskill. Corsair is best.
It will not bottleneck but get i5 minimum. This will best for gaming. Get a non k version of i5 and get a good h97 chipset motherboard. This is for non Overclockers. If you want to overclock then you will need some more money. But if you are on tight budget then it is good. It will not bottleneck at all. It will run good :)
CB
Adsthebest
117
i am on a really tight budget i said you guys to swap parts keeping the same budget not exceeding it
Adsthebest
117
i would better go at local stores to see if the i5 is cheap
thanks for the help folks
