Help me with my Ryzen 5 build?
Dec 25, 2018
13
I recently build a rig with the following specs:
*Ryzen 5 2600
*GTX1070Ti
*Hyper X Fury 2666 8gb ram
*Asus Prime B450-K
*Cooler Master MWE550
I found my card to be underperforming compared to the results found online. Help pls?
It would help some in many titles, also you should be able to oc your processor a bit even on the stock cooler. If you didn't set your ram up in bios to actually run at 2666 its at 2133 or 2400 by default so enable xmp/docp if you haven't already
So if I upgraded my ram to 16gb and make it dual channel will it help? but still at 2666mhz. Truth be told ram with 3200 is too expensive here in my country
Noted on ram part. What do u think would be an ideal speed to OC on R5 2600?
I would love to include 3000+ speed ram but since I'm on a tight budget decided to get 2666 instead.. Plus ram price is so expensive here especially high speed ones. I'm planning to get another stick of ram and make it dual channel first.
OK, and how much the voltage should be for 3.8-3.9? Sorry for asking I'm kinda new to this whole OC thing.
