Hi , I recently bought AMD Ryzen 5 1600X , Gigabyte AB350 gaming 3 ATX board , Corsair 3000Mhz 8x2. Have AMD HD6670 DDR3 2GB Gfx card with Corsair VS550 PSU,Corsair Specs 1 cabinet. With 2 case fans. Front & top. With Corsair H60 AIO liquid cooler. Mounted at rear.In Ryzen Master I can see Temperature being idle all time around 51 degree degree lowest temp maybe 48 I've seen but It fluctuates between 50-60 at idle. Max temperature at 100% load is 62 degree it's doesn't exceed 62-63 . I'm running at Base clock 3.6 GHz . Although in Ryzen master shows 3.7 . It automatically adjust the clock & voltage stays at like 1.29 , 1.30+ & fluctuates. My Ram is set at 2933 1.35vt
Is it something to worry about ? Are X model supposed to be high temp ? Or my room temperature ? The temp is fine for Long long years ? Thanks .
