ookkk, Im on a budget here, so try to help on this one guys.
I plan to use a PC for gaming and rendering, and some programming too.
I was going to build my own pc, buy the parts, its going t take time to do that so I will just buy a pc and upgraded if I need.
That being said, here are some PCs that I might afford, so just let me know wich is best for the price, or if all of them are ok.
First PC:
Case: COUGAR MX310 / Sharkoon VG5-w
CPU: Intel Core i7 7700 Quad-Core 4.2Ghz
Motherboard: Asus B250m-a S1151 / Asrock H270 Pro4 S1151
HDD: 1 TBWD Caviar Blue SATA III 7200RPM 3.5"
SSD: 120GB WD Green Sata3
RAM: 16GB DDR4 2400mhz 2 x 8GB
GPU: GeForce GTX 1060 3GB GDDR5
PS: Raidmax 600W 80 Plus Bronce RX-600AF-B
Total Price: 1.780 Dollars
Second PC:
Case :Cougar Panzer Max
Power Supply: Cougar Stx650 80plus white
Motherboard: MSI Z370 GAMING M5
CPU: Intel Core I7 8700 S1151
Water Cooler?: Corsair Hydro H60
RAM: Ddr4 16gb 2400 Box
HDD: 3.5" Wd Blue 1tb Sata3 7200 Rpm
SSD: Sandisk G26 Plus 240gb Sata 3 2.5"
GPU: EVGA GTX1080 8GB DDR5
Total Price: 2.950 US Dollars
Third PC:
Case: ATX Raidmax Alpha RGB
GPU: Intel Core i7 7700 Quad-Core 4.2Ghz
Water Cooling: DeepCool 120L 120mm
SSD: 240GB WD Green
HDD: 1TB WD 7200rpm Sata3
RAM: Sport Ballistix 16GB DDR4 2400mhz -2 x 8GB-
GPU: GTX 1080 8GB Gaming Gddr5
POWER SUPPLY: Raidmax RX700AF-B 700w reales Certificado 80 Plus Bronze
Total Price: 2.569 US Dollars
Forth PC:
CPU: Intel Core i7 3.4 Ghz (3.9 Ghz Max./ 8 Mb de cache / 4 núcleos y 8 hilos)
RAM: 8 Gb
HDD: 1 Terabyte SATA 7200 RPM
GPU: nVidia GTX 960 2 Gb - DDR5 128 Bits
Motherboard: RJ45 10/100/1000 + 6 USB 2.0 y 3 USB 3.0 + Sonido HD
Case: ABKO nCore Falcon 515G 4 fans led RGB
Power Supply: ATX 600w REALES
Total Price: 1.057 US Dollars
I dont need the fastest PC nor a PC that will run everything on ultra at 120 frames per second.
If you would like to know what games I would play.
-CS:GO
-Overwatch
-Skyrim
-Mount and Blade: Warband
-Assassins Creen Black Flag
-Arma 3
-Squad
Also, I know that AMD CPUs would be better, but I didnt saw a PC with a Ryzen 5 1600 ( I was going to build a PC with that one), later I would try to see companies that build PCs with a part wanted by the customer.
And before people saying that there are better PCs to build myself with a better price buying the parts at amazon or whatever, I dont live in the USA, my country only allows 3 buys outside the country per year wihout having to pay extra for the item.
If you guys could help me. That would be great.
Thanks.
First PC:
Second PC:
Third PC:
SSD: 240GB WD Green
Forth PC:
RAM: 8 Gb
-CS:GO
-Overwatch
-Skyrim
-Arma 3
-Squad
Thanks.
