Help... memory leak
dmacfour
269
My computer is running normally, except one problem.... over a gig of my system memory, which is all that I have, minus virtual memory, is being used up by some unknown application/process. none of the processes in task manager are using more than 50MB. adding up my total memory usage should only be around 300/350MB, and i can't find a free program that detects memory leaks.
the amount of memory being used hovers around 1.01 GB, but it has inreased and decreased rondomly. I don't know at what point it uses up all that memory, because memory useage is around 271 at boot. after playing a game or using some other program, the memory usage inexplicably jumps to 1.01 GB. I don't quite know where to moniter system cache, but none of the system processes are close to/add up to a gig.
