Hello everyone,
I have a serious motherboard problem, it stuck on my case and I cannot get it off. The case doesn't come with any motherboard screws, it just come with motherboard standoffs. I try to match the motherboard screws as much as possible.
It look like this. It have razor teeth.
However, it a really tight fit. It even making squeezing noise when I turn it. Some seam to screw down flat to the motherboard and stay secure, but some couldn't. I try to take it out but couldn't, the standoff move along with the screws. Think 2 of the standoff even crack. Now I just leave it in the case since I can't take it out anymore. Does anyone know if all screws and standoff need to be on the motherboard? The motherboard is not loose like it moving, but I can wiggle the far edge up and down a little since the screw won't screw flush to the motherboard.
I try so many screw and stand off now and it driving my crazy. Is there anywhere I can buy screw and standoffs that bundle together, so I know it fit perfectly together? I can buy the motherboard standoff but not the motherboard screws.
