Help moving my router (2wire gateway) to another room, I have no idea what I am doing.
Andrew Zimmerman
Ok, here this goes. I have a 2wire in one room of my house, and my xbox one is about 50yds away with 3 walls between them. My xbox currently gets 600kbs download time which is absolutely terrible.
What I want to do is move the 2wire to my room, so I can connect it with a ethernet cord to my xbox. In my room I have an old style phone jack with 4 prongs that make a square. I have an adapter that plugs into it and has a phone jack in the bottom of it. However, when I move my 2wire to my room, and set it up the same way as it is in the other room, the red light starts to flash and there is no wireless connection. Literally the only difference in the two setups is in my room the phone cord is plugged into the adapter I described, and in the room it works there is a direct jack for a phone line, no adapter is needed.
Keep in mind I have zero experience with this and I am looking for advice and help. I also have a linksys wrt54gl router still in the box, not sure if I could some how incorporate this to make my wireless range and strength stronger, or if i could keep the 2wire in the room it is working in, and use the linksys in my room and connect it to my xbox via ethernet cord.
I really appreciate any help that can be given. It seriously takes days to download anything on my xbox one.
The simple answer is to keep your modem where it is already working, and not move the location. I think 2wire is a DSL internet company.
The Linksys router you mention is fairly old, and not exactly fast.
http://www.amazon.com/dp/B00IBPLI48/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=35L7HI4OUJSR7&coliid=I2WKWXMFJYVJFN
The simplest fix is a Powerline adapter kit which will send the signal through your home's electrical wiring. The other options would be a new WiFi router, or to run network cable between the rooms (through basement or attic).
How does a powerline adapter kit work exactly? Do i just plug it into a regular wall plug in, and run a ethernet cord from the powerline to my xbox one? I don't understand how that could connect to my router or the internet. I'm sure it does and it is simple, I am just very uneducated in this field.
