settlementmen :
epicoverclock :
officially athlon II X2 270 only supports 1066 but it could go higher. its a deneb chip so it should go to 1333mhz with no problem and you could
do 1600mhz
thank you for replying,
what is denib chip ? is it safe to go to 1333mhz or 1600mhz without damaging my components ?? and whats the good timing and good voltage for 1333mhz or 1600mhz , please answer thanks!!!
AMD Phenoms were based on the Deneb architecture and they officially supported 1333mhz ram. Your cpu is also based on deneb. The difference between your cpu and phenoms is that your chip is missing L3 cache. Your cpu should handle 1333mhz nicely. I recommend you go for 1333mhz and tight timings. The timings depend on your ram. What is the brand and model of your ram?
