[SOLVED] HELP my cpu is terrible underperforming
i got u bro
Thanks.
Have a look in the ThrottleStop C States window. These CPUs need to have either core C3, C6 or C7 enabled in the BIOS so they can go up to 3500 MHz when one core is active.
https://www.cpu-world.com/CPUs/Xeon/Intel-Xeon E3-1220 v3.html
Run a TS Bench - 1 Thread test and you should see evidence of the 35 multiplier as long as you do not have too much stuff running in the background keeping the other cores active. Best to turn off that other monitoring utility. The load it puts on your CPU will interfere with reaching the maximum multiplier. It also has a hard time recognizing when the maximum multiplier is being used.
i got u bro
Thanks.
