K Kuba_5 Commendable Feb 3, 2017 2 0 1,510 Feb 3, 2017 #1 My fuse box blows every time I turn on my PC? Im just switching cases nothing else. Corsair rm650x psu
Solution geofelt Feb 3, 2017 If your pc worked before, you have probably shorted out something in the process of changing out your case. Take it all apart and test if it works with the motherboard and parts outside of the case.
Rocky Bennett Dignified May 25, 2016 3,226 2 14,015 Feb 3, 2017 #2 Does your computer work? Does it do this on every circuit that you plug it into? Upvote 0 Downvote
K Kuba_5 Commendable Feb 3, 2017 2 0 1,510 Feb 3, 2017 #3 I dont know if it works because the fuse keeps blowing! Upvote 0 Downvote
geofelt Titan Oct 9, 2006 56,049 4,859 174,240 Feb 3, 2017 Solution #4 If your pc worked before, you have probably shorted out something in the process of changing out your case. Take it all apart and test if it works with the motherboard and parts outside of the case. Upvote 0 Downvote Solution
