Help my modify my build to be cheaper.
lordzharks
8
I am new to building PC's, as this will be my first one I have ever done, and as of now, its just above $1000, but I can't really afford that. I won't be overclocking and I will mostly be gaming with this rig. My budget can vary, but I wanna see how low I can get this build without losing the GPU.
BUILD:
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor
GPU: Gigabyte GeForce GTX 970 4GB WINDFORCE 3X Video Card
MOBO: Asus Maximus VI Hero ATX LGA1150 Motherboard
RAM: G.Skill Sniper Series 8GB (2 x 4GB) DDR3-2400 Memory
PSU: Corsair CX 750W 80+ Bronze Certified Semi-Modular ATX Power Supply
HDD: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
EDIT:
Also, I will plan on getting a seconond GPU for sli in the future.
CPU- i5 4690 /i5 4460(200$)
PSU- antec 550/600W ~50$ PS- the corsair CX has a bit low quality capacitors
Mobo: any z 97/h97 board (if you dont wnat sli) around 110$
the CPU alome would bring down the cost of the rig down
hope this helps!!
CPU: Intel Core i5-4440 3.1GHz Quad-Core Processor ($169.99 @ Newegg)
Motherboard: Asus H97-PLUS ATX LGA1150 Motherboard ($101.99 @ Directron)
Memory: G.Skill Sniper 8GB (2 x 4GB) DDR3-1600 Memory ($64.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($53.77 @ OutletPC)
Video Card: Asus GeForce GTX 970 4GB STRIX Video Card ($356.13 @ Newegg)
Case: Corsair 200R ATX Mid Tower Case ($49.99 @ Amazon)
Power Supply: XFX 650W 80+ Bronze Certified Semi-Modular ATX Power Supply ($64.99 @ NCIX US)
Total: $848.85
Generated by PCPartPicker 2014-11-23 14:17 EST-0500
Do you already have a case? and, where's your location?
