[SOLVED] Help, my pc isnt booting up.
Natrium
42
I dont know in which category to place this in but anyways. I recently built my computer, and when i turned it on, the cpu fan started, all the rgb started, but the case fans didnt spin at all, CMOS lights red on VGA, DRAM, CPU, BOOT. No post screen or anything.
CPU: Ryzen 2600
GPU: RTX 2060 6GB Z Gaming
Ram: Vengeance Pro 2x8 gb 3200mhz rgb
PSU: Corsair 650 watt semi modular bronze rated
Cooler: Arctic Freezer 34
Mobo: B450 Aorus Pro
Case: NZXT H500
HDD: Seagate barracuda 1TB
SSD: Kingston A400 240GB
Does my ryzen 2600 even have an integrated graphics?
Welcome to the forums my friend!
Please see this guide first and follow every step: https://forums.tomshardware.com/thr...ng-about-post-boot-no-video-problems.1285536/
Then let us know how it goes.
List all your components. Remove your GPU and try again with integrated graphics
CPU: Ryzen 2600
Case: NZXT H500
CPU: Ryzen 2600
Case: NZXT H500
Yes but what exact model?
Everything is working perfectly fine now, I went and bought two fan splitters 4 pin <<, and connected my fans to them. One fan splitter has 2 ends, so i can control my exhaust and my intake individually. Seems like fan cabels with 3 pins won't work on 4 pin connectors. I'll keep this here if someone has the same issue, thanks anyways!
