help my speed
mikecz1
9
win 7 pro inel(R) i7 Core(TM) i7 - 3770 cpu @ 3.50GHz 3.80 GHz installed memeory 32 GB mother board is a gigabuytez68xp-ud3 playing sc2 my fps rate some times drops to 4 fps what is the best way I can increse my speed being on a budget, that is my setup and I have Comcast blast plus 55 to 57 down speed, please help or tell me where to post this, thanks you in advance
G
I don't think you need an upgrade. The Intel HD Graphics inside your Core i7-3770 do fine with StarCraft 2. Maybe it's some software or virus. Does your Windows load a lot of stuff at start up?
Consider downloading HijackThis, run it and send us your log file.
Are you running it as admin? Restart your PC, login and do not open any program, just run the HijackThis before anything. Use scan system & save log.
Logfile of Trend Micro HijackThis v2.0.4
Scan saved at 8:16:53 PM, on 3/28/2014
Platform: Windows 7 SP1 (WinNT 6.00.3505)
MSIE: Internet Explorer v11.0 (11.00.9600.16521)
Boot mode: Normal
Running processes:
C:\Program Files (x86)\NVIDIA Corporation\Update Core\NvBackend.exe
C:\Windows\System32\TiltWheelMouse.exe
C:\Program Files (x86)\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe
C:\Users\MikeCz\AppData\Local\Amazon Cloud Player\Amazon Music Helper.exe
C:\Users\MikeCz\AppData\Roaming\Verizon\UA_ar\UA.exe
C:\Program Files (x86)\Intel\Intel(R) Rapid Storage Technology\IAStorIcon.exe
C:\Program Files (x86)\Adobe\Acrobat 9.0\Acrobat\acrobat_sl.exe
C:\Program Files (x86)\Adobe\Acrobat 9.0\Acrobat\acrotray.exe
C:\Program Files (x86)\Real\RealPlayer\Update\realsched.exe
C:\Program Files (x86)\Logitech\LWS\Webcam Software\LWS.exe
C:\Program Files (x86)\AVG\AVG2013\avgui.exe
C:\Program Files (x86)\Logitech\LWS\Webcam Software\CameraHelperShell.exe
C:\Program Files (x86)\GamingWonderland\bar\1.bin\gtbrmon.exe
C:\Program Files (x86)\MapsGalaxy_39\bar\1.bin\39brmon.exe
C:\Program Files (x86)\Splashtop\Splashtop Connect\ZyngaGamesAgent.exe
C:\Program Files (x86)\iTunes\iTunesHelper.exe
C:\Program Files (x86)\Internet Explorer\IEXPLORE.EXE
C:\Program Files (x86)\Google\Google Toolbar\GoogleToolbarUser_32.exe
C:\Program Files (x86)\Splashtop\Splashtop Connect IE\STCHelper.exe
C:\Program Files (x86)\RealNetworks\RealDownloader\recordingmanager.exe
C:\Program Files (x86)\Trend Micro\HiJackThis\HiJackThis.exe
R1 - HKCU\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/fwlink/p/?LinkId=255141
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://go.microsoft.com/fwlink/?LinkId=54896
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/p/?LinkId=255141
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,SearchAssistant =
R0 - HKLM\Software\Microsoft\Internet Explorer\Search,CustomizeSearch =
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Local Page = C:\Windows\SysWOW64\blank.htm
R1 - HKCU\Software\Microsoft\Windows\CurrentVersion\Internet Settings,ProxyOverride = *.local
R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName =
R3 - URLSearchHook: Splashtop Connect SearchHook - {0F3DC9E0-C459-4a40-BCF8-747BD9322E10} - C:\Program Files (x86)\Splashtop\Splashtop Connect IE\AddressBarSearch.dll
R3 - URLSearchHook: (no name) - {a8625cb7-85fe-4936-92a4-b2a7c925209e} - C:\Program Files (x86)\GamingWonderland\bar\1.bin\gtSrcAs.dll
R3 - URLSearchHook: (no name) - {26842a09-ffa8-4e2c-ae12-0c80f01c3295} - C:\Program Files (x86)\MapsGalaxy_39\bar\1.bin\39SrcAs.dll
F2 - REG:system.ini: UserInit=userinit.exe
O2 - BHO: (no name) - {02478D38-C3F9-4efb-9B51-7695ECA05670} - (no file)
O2 - BHO: Splashtop Connect VisualBookmark - {0E5680D1-BF44-4929-94AF-FD30D784AD1D} - C:\Program Files (x86)\Splashtop\Splashtop Connect IE\STC.dll
O2 - BHO: AcroIEHelperStub - {18DF081C-E8AD-4283-A596-FA578C2EBDC3} - C:\Program Files (x86)\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll
O2 - BHO: Toolbar BHO - {1e91a655-bb4b-4693-a05e-2edebc4c9d89} - C:\PROGRA~2\MAPSGA~2\bar\1.bin\39bar.dll
O2 - BHO: RealNetworks Download and Record Plugin for Internet Explorer - {3049C3E9-B461-4BC5-8870-4C09146192CA} - C:\ProgramData\RealNetworks\RealDownloader\BrowserPlugins\IE\rndlbrowserrecordplugin.dll
O2 - BHO: Search Assistant BHO - {71c1d63a-c944-428a-a5bd-ba513190e5d2} - C:\Program Files (x86)\MapsGalaxy_39\bar\1.bin\39SrcAs.dll
O2 - BHO: Toolbar BHO - {7c8f8fe5-9785-4f74-bcf8-895ef9752d97} - C:\PROGRA~2\GAMING~2\bar\1.bin\gtbar.dll
O2 - BHO: Google Toolbar Helper - {AA58ED58-01DD-4d91-8333-CF10577473F7} - C:\Program Files (x86)\Google\Google Toolbar\GoogleToolbar_32.dll
O2 - BHO: Search Assistant BHO - {ab5d199e-9659-47a2-930b-fc3b69061353} - C:\Program Files (x86)\GamingWonderland\bar\1.bin\gtSrcAs.dll
O2 - BHO: Adobe PDF Conversion Toolbar Helper - {AE7CD045-E861-484f-8273-0445EE161910} - C:\Program Files (x86)\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll
O2 - BHO: SkypeIEPluginBHO - {AE805869-2E5C-4ED4-8F7B-F1F7851A4497} - C:\Program Files (x86)\Skype\Toolbars\Internet Explorer\SkypeIEPlugin.dll
O2 - BHO: URLRedirectionBHO - {B4F3A835-0E21-4959-BA22-42B3008E02FF} - C:\PROGRA~2\MICROS~1\Office14\URLREDIR.DLL
O2 - BHO: SmartSelect - {F4971EE7-DAA0-4053-9964-665D8EE6A077} - C:\Program Files (x86)\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll
O3 - Toolbar: Adobe PDF - {47833539-D0C5-4125-9FA8-0819E2EAAC93} - C:\Program Files (x86)\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll
O3 - Toolbar: GamingWonderland - {a899079d-206f-43a6-be6a-07e0fa648ea0} - C:\Program Files (x86)\GamingWonderland\bar\1.bin\gtbar.dll
O3 - Toolbar: MapsGalaxy - {364ea597-e728-4ce4-bb4a-ed846ef47970} - C:\Program Files (x86)\MapsGalaxy_39\bar\1.bin\39bar.dll
O3 - Toolbar: Google Toolbar - {2318C2B1-4965-11d4-9B18-009027A5CD4F} - C:\Program Files (x86)\Google\Google Toolbar\GoogleToolbar_32.dll
O4 - HKLM\..\Run: [IAStorIcon] C:\Program Files (x86)\Intel\Intel(R) Rapid Storage Technology\IAStorIcon.exe
O4 - HKLM\..\Run: [Adobe Acrobat Speed Launcher] "C:\Program Files (x86)\Adobe\Acrobat 9.0\Acrobat\Acrobat_sl.exe"
O4 - HKLM\..\Run: [Acrobat Assistant 8.0] "C:\Program Files (x86)\Adobe\Acrobat 9.0\Acrobat\Acrotray.exe"
O4 - HKLM\..\Run: [TkBellExe] "C:\Program Files (x86)\Real\RealPlayer\Update\realsched.exe" -osboot
O4 - HKLM\..\Run: [LWS] C:\Program Files (x86)\Logitech\LWS\Webcam Software\LWS.exe -hide
O4 - HKLM\..\Run: [AVG_UI] "C:\Program Files (x86)\AVG\AVG2013\avgui.exe" /TRAYONLY
O4 - HKLM\..\Run: [BCSSync] "C:\Program Files (x86)\Microsoft Office\Office14\BCSSync.exe" /DelayServices
O4 - HKLM\..\Run: [Adobe ARM] "C:\Program Files (x86)\Common Files\Adobe\ARM\1.0\AdobeARM.exe"
O4 - HKLM\..\Run: [GamingWonderland Browser Plugin Loader] C:\PROGRA~2\GAMING~2\bar\1.bin\gtbrmon.exe
O4 - HKLM\..\Run: [MapsGalaxy EPM Support] "C:\PROGRA~2\MAPSGA~2\bar\1.bin\39medint.exe" T8EPMSUP.DLL,S
O4 - HKLM\..\Run: [MapsGalaxy Search Scope Monitor] "C:\PROGRA~2\MAPSGA~2\bar\1.bin\39srchmn.exe" /m=2 /w /h
O4 - HKLM\..\Run: [MapsGalaxy_39 Browser Plugin Loader] C:\Program Files (x86)\MapsGalaxy_39\bar\1.bin\39brmon.exe
O4 - HKLM\..\Run: [MapsGalaxy_39 Browser Plugin Loader 64] C:\Program Files (x86)\MapsGalaxy_39\bar\1.bin\39brmon64.exe
O4 - HKLM\..\Run: [STCAgent] "C:\Program Files (x86)\Splashtop\Splashtop Connect IE\STCAgent.exe"
O4 - HKLM\..\Run: [ZyngaGamesAgent] "C:\Program Files (x86)\Splashtop\Splashtop Connect\ZyngaGamesAgent.exe"
O4 - HKLM\..\Run: [iTunesHelper] "C:\Program Files (x86)\iTunes\iTunesHelper.exe"
O4 - HKCU\..\Run: [swg] "C:\Program Files (x86)\Google\GoogleToolbarNotifier\GoogleToolbarNotifier.exe"
O4 - HKCU\..\Run: [Amazon Cloud Player] "C:\Users\MikeCz\AppData\Local\Amazon Cloud Player\Amazon Music Helper.exe"
O4 - HKUS\S-1-5-19\..\Run: [Sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /autoRun (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-19\..\RunOnce: [mctadmin] C:\Windows\System32\mctadmin.exe (User 'LOCAL SERVICE')
O4 - HKUS\S-1-5-20\..\Run: [Sidebar] %ProgramFiles%\Windows Sidebar\Sidebar.exe /autoRun (User 'NETWORK SERVICE')
O4 - HKUS\S-1-5-20\..\RunOnce: [mctadmin] C:\Windows\System32\mctadmin.exe (User 'NETWORK SERVICE')
O4 - HKUS\S-1-5-18\..\RunOnce: [SPReview] "C:\Windows\System32\SPReview\SPReview.exe" /sp:1 /errorfwlink:"http://go.microsoft.com/fwlink/?LinkID=122915" /build:7601 (User 'SYSTEM')
O4 - HKUS\.DEFAULT\..\RunOnce: [SPReview] "C:\Windows\System32\SPReview\SPReview.exe" /sp:1 /errorfwlink:"http://go.microsoft.com/fwlink/?LinkID=122915" /build:7601 (User 'Default user')
O4 - Startup: Verizon Wireless Software Utility Application for Android – Samsung.lnk = MikeCz\AppData\Roaming\Verizon\UA_ar\UA.exe
O8 - Extra context menu item: Append Link Target to Existing PDF - res://C:\Program Files (x86)\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll/AcroIEAppendSelLinks.html
O8 - Extra context menu item: Append to Existing PDF - res://C:\Program Files (x86)\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll/AcroIEAppend.html
O8 - Extra context menu item: Convert Link Target to Adobe PDF - res://C:\Program Files (x86)\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll/AcroIECaptureSelLinks.html
O8 - Extra context menu item: Convert to Adobe PDF - res://C:\Program Files (x86)\Common Files\Adobe\Acrobat\ActiveX\AcroIEFavClient.dll/AcroIECapture.html
O8 - Extra context menu item: E&xport to Microsoft Excel - res://C:\PROGRA~2\MICROS~1\Office12\EXCEL.EXE/3000
O9 - Extra button: Skype Click to Call - {898EA8C8-E7FF-479B-8935-AEC46303B9E5} - C:\Program Files (x86)\Skype\Toolbars\Internet Explorer\SkypeIEPlugin.dll
O9 - Extra button: Research - {92780B25-18CC-41C8-B9BE-3C9C571A8263} - C:\PROGRA~2\MICROS~1\Office12\REFIEBAR.DLL
O11 - Options group: [ACCELERATED_GRAPHICS] Accelerated graphics
O18 - Protocol: skype-ie-addon-data - {91774881-D725-4E58-B298-07617B9B86A8} - C:\Program Files (x86)\Skype\Toolbars\Internet Explorer\SkypeIEPlugin.dll
O18 - Protocol: skype4com - {FFC8B962-9B40-4DFF-9458-1830C7DD7F5D} - C:\PROGRA~2\COMMON~1\Skype\SKYPE4~1.DLL
O23 - Service: Adobe Flash Player Update Service (AdobeFlashPlayerUpdateSvc) - Adobe Systems Incorporated - C:\Windows\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
O23 - Service: @%SystemRoot%\system32\Alg.exe,-112 (ALG) - Unknown owner - C:\Windows\System32\alg.exe (file missing)
O23 - Service: Apple Mobile Device - Apple Inc. - C:\Program Files (x86)\Common Files\Apple\Mobile Device Support\AppleMobileDeviceService.exe
O23 - Service: AppleChargerSrv - Unknown owner - C:\Windows\system32\AppleChargerSrv.exe (file missing)
O23 - Service: AVGIDSAgent - AVG Technologies CZ, s.r.o. - C:\Program Files (x86)\AVG\AVG2013\avgidsagent.exe
O23 - Service: AVG WatchDog (avgwd) - AVG Technologies CZ, s.r.o. - C:\Program Files (x86)\AVG\AVG2013\avgwdsvc.exe
O23 - Service: Bonjour Service - Apple Inc. - C:\Program Files\Bonjour\mDNSResponder.exe
O23 - Service: @%SystemRoot%\system32\efssvc.dll,-100 (EFS) - Unknown owner - C:\Windows\System32\lsass.exe (file missing)
O23 - Service: @%systemroot%\system32\fxsresm.dll,-118 (Fax) - Unknown owner - C:\Windows\system32\fxssvc.exe (file missing)
O23 - Service: FLEXnet Licensing Service - Macrovision Europe Ltd. - C:\Program Files (x86)\Common Files\Macrovision Shared\FLEXnet Publisher\FNPLicensingService.exe
O23 - Service: Google Update Service (gupdate) (gupdate) - Google Inc. - C:\Program Files (x86)\Google\Update\GoogleUpdate.exe
O23 - Service: Google Update Service (gupdatem) (gupdatem) - Google Inc. - C:\Program Files (x86)\Google\Update\GoogleUpdate.exe
O23 - Service: Google Software Updater (gusvc) - Google - C:\Program Files (x86)\Google\Common\Google Updater\GoogleUpdaterService.exe
O23 - Service: Intel(R) Rapid Storage Technology (IAStorDataMgrSvc) - Intel Corporation - C:\Program Files (x86)\Intel\Intel(R) Rapid Storage Technology\IAStorDataMgrSvc.exe
O23 - Service: @%SystemRoot%\system32\ieetwcollectorres.dll,-1000 (IEEtwCollectorService) - Unknown owner - C:\Windows\system32\IEEtwCollector.exe (file missing)
O23 - Service: iPod Service - Apple Inc. - C:\Program Files\iPod\bin\iPodService.exe
O23 - Service: @keyiso.dll,-100 (KeyIso) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: Intel(R) Management and Security Application Local Management Service (LMS) - Intel Corporation - C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\LMS\LMS.exe
O23 - Service: MapsGalaxyService (MapsGalaxy_39Service) - COMPANYVERS_NAME - C:\PROGRA~2\MAPSGA~2\bar\1.bin\39barsvc.exe
O23 - Service: Mozilla Maintenance Service (MozillaMaintenance) - Mozilla Foundation - C:\Program Files (x86)\Mozilla Maintenance Service\maintenanceservice.exe
O23 - Service: @comres.dll,-2797 (MSDTC) - Unknown owner - C:\Windows\System32\msdtc.exe (file missing)
O23 - Service: Nero BackItUp Scheduler 3 - Nero AG - C:\Program Files (x86)\Nero\Nero8\Nero BackItUp\NBService.exe
O23 - Service: @%SystemRoot%\System32\netlogon.dll,-102 (Netlogon) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: NMIndexingService - Nero AG - C:\Program Files (x86)\Common Files\Nero\Lib\NMIndexingService.exe
O23 - Service: NVIDIA Network Service (NvNetworkService) - NVIDIA Corporation - C:\Program Files (x86)\NVIDIA Corporation\NetService\NvNetworkService.exe
O23 - Service: NVIDIA Streamer Service (NvStreamSvc) - NVIDIA Corporation - C:\Program Files\NVIDIA Corporation\NvStreamSrv\nvstreamsvc.exe
O23 - Service: NVIDIA Display Driver Service (nvsvc) - Unknown owner - C:\Windows\system32\nvvsvc.exe (file missing)
O23 - Service: PLFlash DeviceIoControl Service - Prolific Technology Inc. - C:\Windows\SysWOW64\IoctlSvc.exe
O23 - Service: @%systemroot%\system32\psbase.dll,-300 (ProtectedStorage) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: RealNetworks Downloader Resolver Service - Unknown owner - C:\Program Files (x86)\RealNetworks\RealDownloader\rndlresolversvc.exe
O23 - Service: @%systemroot%\system32\Locator.exe,-2 (RpcLocator) - Unknown owner - C:\Windows\system32\locator.exe (file missing)
O23 - Service: @%SystemRoot%\system32\samsrv.dll,-1 (SamSs) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: Splashtop Connect Service (SCBackService) - Splashtop Inc. - C:\Program Files (x86)\Splashtop\Splashtop Connect\BackService.exe
O23 - Service: Skype Updater (SkypeUpdate) - Skype Technologies - C:\Program Files (x86)\Skype\Updater\Updater.exe
O23 - Service: @%SystemRoot%\system32\snmptrap.exe,-3 (SNMPTRAP) - Unknown owner - C:\Windows\System32\snmptrap.exe (file missing)
O23 - Service: @%systemroot%\system32\spoolsv.exe,-1 (Spooler) - Unknown owner - C:\Windows\System32\spoolsv.exe (file missing)
O23 - Service: @%SystemRoot%\system32\sppsvc.exe,-101 (sppsvc) - Unknown owner - C:\Windows\system32\sppsvc.exe (file missing)
O23 - Service: NVIDIA Stereoscopic 3D Driver Service (Stereo Service) - NVIDIA Corporation - C:\Program Files (x86)\NVIDIA Corporation\3D Vision\nvSCPAPISvr.exe
O23 - Service: @%SystemRoot%\system32\ui0detect.exe,-101 (UI0Detect) - Unknown owner - C:\Windows\system32\UI0Detect.exe (file missing)
O23 - Service: Intel(R) Management and Security Application User Notification Service (UNS) - Intel Corporation - C:\Program Files (x86)\Intel\Intel(R) Management Engine Components\UNS\UNS.exe
O23 - Service: @%SystemRoot%\system32\vaultsvc.dll,-1003 (VaultSvc) - Unknown owner - C:\Windows\system32\lsass.exe (file missing)
O23 - Service: @%SystemRoot%\system32\vds.exe,-100 (vds) - Unknown owner - C:\Windows\System32\vds.exe (file missing)
O23 - Service: @%systemroot%\system32\vssvc.exe,-102 (VSS) - Unknown owner - C:\Windows\system32\vssvc.exe (file missing)
O23 - Service: @%SystemRoot%\system32\Wat\WatUX.exe,-601 (WatAdminSvc) - Unknown owner - C:\Windows\system32\Wat\WatAdminSvc.exe (file missing)
O23 - Service: @%systemroot%\system32\wbengine.exe,-104 (wbengine) - Unknown owner - C:\Windows\system32\wbengine.exe (file missing)
O23 - Service: Splashtop Connect Firefox Software Updater Service (WCUService_STC_FF) - Splashtop Inc. - C:\Program Files (x86)\Splashtop\Splashtop Connect Firefox Software Updater\WCUService.exe
O23 - Service: Splashtop Connect IE Software Updater Service (WCUService_STC_IE) - Splashtop Inc. - C:\Program Files (x86)\Splashtop\Splashtop Connect IE Software Updater\WCUService.exe
O23 - Service: @%Systemroot%\system32\wbem\wmiapsrv.exe,-110 (wmiApSrv) - Unknown owner - C:\Windows\system32\wbem\WmiApSrv.exe (file missing)
O23 - Service: @%PROGRAMFILES%\Windows Media Player\wmpnetwk.exe,-101 (WMPNetworkSvc) - Unknown owner - C:\Program Files (x86)\Windows Media Player\wmpnetwk.exe (file missing)
End of file - 16284 bytes
There is a bunch of stuff that I would suggest you to remove from the load list at start up system. These are only suggestion! Maybe some of them you actually want to be loaded up.
UA.exe
acrobat_sl.exe
acrotray.exe
realsched.exe
39brmon.exe
ZyngaGamesAgent.exe
iTunesHelper.exe
STCHelper.exe
If you miss something, or a program do not load as expected, just undo the following settings:
Ctrl + Alt + Del open your Task Manager. There's a tab with a list of start-up programs. Disable one-by-one.
And a question: how many slots of memory are you using? 4x8GB memories?
