[HELP] My STRAFE RGB Corsair Keyboard is not working..
aiden_15
So recently I spilled water on my keyboard but I don't think it went on to the keys, it was working normally but then out of nowhere it started glitching out. I restarted my computer and then all I got from my keyboard was the Scroll, Caps, and Num lock lights on. I click every key but nothing happens, I unplugged it and plugged it in again. It is still not working, all I can see are the 3 white lights for the lock keys. Help me please 🙁
Would expect that water did get inside and the keyboard may still have water inside.
Check the manual or Cosair's website - they may have a "recommended" procedure regarding spills.
Turn the keyboard upside down over a towel and tap the ends and sides of the keyboard gently with heel of your hand. See if more water drips out.
Wrap the keyboard in an absorbant cloth and place the entire package somewhere warm and dry. Not in the sun or under a hot air duct.
Or set the keyboard on a table with a small fan blowing air across it.
There are numberous links and videos online with other DIY solutions. Those solutions may or may not invalidate the keyboard's warranty.
