Question Help need for build from scatch
oldschxxl
11
4
515
Hello, I've been trying to build a suitable build with the Ryzen 7 7800x3d or the 7700/x for more than 1 week. ( maybe if you guys got any other good option ill take it ) but every time I'm dissatisfied and the reason why I'm posting now is because I just don't get any help on other sites. I would like to ask you for help. My budget is not particularly big, let's say 1200-1400 maximum 1500€. if it's a few euros over it, not bad either. I would get my parts from a local vendor called ARLT Computers. This means that all parts listed on major Internet retailers are not available at ARLT Computers.
I've been having serious problems with my old pc for the past few months, which is over 10 years old. Now it's just the time for an upgrade and new build, hopefully i can find hear some help, cause i will hit tomorrow the store.
i don't know which cpu and mainboard i should get. every time i finish a build i start from 0 again because i read on other sites that the parts don't seem to be good. I actually like the h5 flow vom nzxt and the h7 flow. if you guys have any other recommandations looking as good like these, i'll take it.
GPU wise i'd go with the rx 6800 xt ( will be bought first of next month )
At this point i should mention, that my setup will be in attic. i got no other choice. attic can get hot, up to +30°c.
What will be the primary uses of your PC and what is your monitor resolution or is a monitor to be included in the budget?
Hi there. Use will be primary for Gaming mostly, some photoshop and streaming.
Monitor will be also bought first of next month, saw a few on sale nearby 144/165hz, which means not included in budget. This is what i've come up with so far few days ago but i got no idea if that fits. can i just also change 7700 to 7800x3d with all that?
Will your monitor resolution be 1080 or 1440?
Here's a few ideas including a single 2TB SSD for now.
https://geizhals.de/fractal-design-focus-2-rgb-weiss-fd-c-foc2a-04-a2792761.html
Fractal Design Focus 2 RGB ATX Mid Tower Case €77,98
Rear exhaust fan for that case.
Arctic P12 PWM 120mm 4-Pin Case Fan €6,68
https://geizhals.de/corsair-rme-series-2023-rm750e-750w-atx-3-0-cp-9020262-eu-a2928368.html
Corsair RM750e 750W (2023) 80+ Gold Modular ATX 3.0 Power Supply €110,34
https://geizhals.de/msi-pro-b650-p-wifi-a2824301.html
MSI Pro B650-P WIFI €189,00
https://geizhals.de/amd-ryzen-7-7700x-100-100000591wof-a2801229.html
AMD Ryzen 7 7700X €319,00
https://www.ebay.de/itm/204132443208?hash=item2f873de448
Deepcool AG620 WH ARGB Dual Tower CPU Cooler €57,65
Low profile RAM so that it doesn't impede that dual tower cpu cooler.
G.Skill Ripjaws S5 DDR5-6000 32GB (2x16GB) CL30 €114,90
https://geizhals.de/samsung-ssd-970-evo-plus-2tb-mz-v7s2t0bw-a1972736.html
Samsung 970 EVO Plus 2TB M.2 NVMe SSD €98,24
Total: €973.79
A better look at those components.
https://www.fractal-design.com/products/cases/focus/focus-2/rgb-white-tg-clear-tint/
https://www.msi.com/Motherboard/PRO-B650-P-WIFI
Reactions: oldschxxl
This is not avilable in the Arlt Store.
6000 version is also not available in arlt store. max is 5600
Total: €973.79
I could order the deepcool, but then i gotta build all the parts together myself, i might be able to do it, was thinking earlier about that, but can i do it, is another question 🤔 cause when i let ARLT build that whole thing, it costs me extra 150€
few questions also, does PCIe3.0 and 4.0 make a lot difference? is it possible to make it a bit more fancier with rgb? is air cooling better then water cooling? Which Case also are outstanding with tripple fans at the front maybe or 2 and looks good in rgb lights? 😀 or is that much? is the h5 flow to small for these parts or the h7 flow?
so far it looks like This
Reactions: Why_Me
Total: €973.79
few questions also, does PCIe3.0 and 4.0 make a lot difference? is it possible to make it a bit more fancier with rgb? is air cooling better then water cooling? Which Case also are outstanding with tripple fans at the front maybe or 2 and looks in in rgb? 😀 or is that much
I prefer air cooling myself. Less hassle and air coolers last longer. A dual tower air cooler will usually outperform a 240 AIO and do it for less money. Little to no difference between PCIe 3 and PCIe 4 SSD's.
For a top of the line ARGB case then this one for sure.
https://geizhals.de/lian-li-lancool-216-rgb-a2847025.html
https://lian-li.com/product/lancool-216/
View: https://www.youtube.com/watch?v=VmpaN61OISA
i should have mentioned that im trying to go full white build with a little touch of black so it fits in my room and table with some rgb in it, i edited my text on top, looks like you have replied the same time i edited 😊 i see then air cooler it is, but that case also not available in arlt store.
choices i have here is just
Reactions: Why_Me
AMD revealed the first Ryzen 7000 Series processors on 29 August 2022.
Last year it was in augus so it happsuppose it willen in august also this year or late september,new tecnology is incoming imo
im running currently my pc with a fan which is used for summer times 🤣
hopefully prices will drop earlier
Reactions: Why_Me
