HELP NEEDED irql not less or equal while gaming
Apr 6, 2018
4
Hello everyone i'm really in need of some help... My computer that i built the beginning of feb keeps bsod when im gaming randomly. the specs are
Asus Maximus x Hero Wifi-ac Mobo
Intel i7-8700k overclocked to 4.9 ghz at 1.25 volts with avx of 2
16gb GSkill Trident Z RGB DDR4 ram XMP profile of 3000mhz at 1.35v
Samsung 860 evo 500gb ssd
Corsair Hx750i Powersupply
gtx 1080 Founders edition nvidia
I have a swiftech h220x prestige aio fro the cpu cooler.
This computer is driving me absolutely insane ive tried everything that i can think of and it wont fix the problem. When i play gta 5 the pc will randomly crash and give me the bsod error irql not less or equal. The pc runs the benchmark of gta 5 flawlessly runs the game flawlessly but will randomly crash. The things i've done to try fix the issue are... I ran Checkdsk and repair disk with no errors. I ran memtest on boot for 4 passes with no errors. I have stress tested every piece of hardware independently and i can not recreate the crash. I ran every test in occt for 2 hrs each no issues no crashes i've run intel burn test with prime 95 at the same time no crashes. Im pulling my hair out over this any help would be greatly appreciated. All my drivers are up to date. Ive updated the bios as well. Ive tried Uninstalling and reinstalling all my drivers and still have the issue. I've tried everything i can think of and cant figure it out. Help Needed thanks so much in advance to any that can help me with this. this is my 4th pc ive built so im no newbie
this what whocrashed gave me for the last bsod
crash dump file: C:\Windows\Minidump\040618-4562-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x175510)
Bugcheck code: 0xA (0x0, 0xFF, 0x0, 0xFFFFF80200D55A91)
Error: IRQL_NOT_LESS_OR_EQUAL
file path: C:\Windows\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that Microsoft Windows or a kernel-mode driver accessed paged memory at DISPATCH_LEVEL or above. This is a software bug.
This bug check belongs to the crash dump test that you have performed with WhoCrashed or other software. It means that a crash dump file was properly written out.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
That BSOD is usually related to an unstable overclock.
2 hours is barely a stress test when it comes to overclocking, I would be running Prime95 26.6 small FFTs for 12-24 hours for a proper stress test.
