Firstly, I would like to quickly go over my issue and then I'll say what I've tried already.
Specs:
- MSI MPG X570 Gaming Edge WiFi
-AMD Ryzen 5800X
-RTX 3080Fe
- Cooler Master 850W 80+ Gold Rated MWE PSU
- 500GB Sabrent NVME SSD
- Noctua DH15
I have used my PC for two years now and I decided to double my RAM (Corsair Vengeance 3600MHz C18) from 2x8 to 4x8. As they were in the way I had to unplug the two 8pin power connectors of my 3080 and unclamp the front facing can of my CPU cooler, then put the two new sticks in the A1 and B1 slot (with the CMOS removed), plugged the 8pins back in, started my PC and pressed F2 to boot with default settings. That was about at 6pm and I would continue to use my PC as usual (play games, watch streams and have multiple applications/tabs open) until about 1am when I went to sleep and shut down my PC as always. The next morning I started my PC and immediately before I reached even the login screen it blackscreens, I get no DisplayPort signal and it restarts. Sometimes after crashing it will prepare automatic repair but most of the time it crashes again and then restarts without repair mode. I've never gotten an error message. Ever since then I keep having the same problem and I've gotten a max. CPU uptime of ~1 hour.
Now to the things I've tried to fix this issue:
First thing I did was remove my new sticks and go back to the old setup but no change. I then checked all connections, booted in safe mode, restored an old Windows version, reset my PC (with my files kept and surprisingly it didn't crash while resetting), followed the XMP/overclocking guide in this thread (tried single RAM sticks in A2/B2 at default settings, then tried them all with a manually set higher voltage of max 1.4V), updated BIOS, I've tried enabling an XMP. I have tried using Memtest86 but after the progress bar reached 100% I didn't get the image with the result.
What is so weird to me about this issue, is how the RAM and everything else seemed to work fine and then the next morning it's completely different. I would believe that if me putting in new RAM was the cause of this problem I would've seen the effects immediately and not the day after?
I'm really confused atm and I would appreciate any help
Specs:
-AMD Ryzen 5800X
-RTX 3080Fe
- Noctua DH15
