Help. No display after knock
Chris-22
Commendable
Apr 3, 2016
17
Help! I bumped my computer while dusting around it and I heard that noise you get when you unplug usb devices and then the screen went black and says no signal! But my music on the PC was still playing. I have checked all cables and restarted the PC several times. It seems to technically work but no display. Thanks
Does it have a dedicated graphics card? If so, it may have come dislodged from the PCI-E slot. Power down the computer and unplug it from the wall. Then remove the graphics card and reseat it in the PCI-E slot. If it has a PCI-E power connector, make sure it's fully inserted. Then try to boot up.
MERGED QUESTION
Question from Chris-22 : "Help. No dislplay after knock"
