Basically, I dont know what to do anymore. I have tried literally everything.
But my PC started crashing a lot (sometimes BSOD with different errors). After a Ubuntu Install (Without removing Windows).
I have tried to install Windows and other OS (Arch Linux, Ubuntu... u name it I tried it) but it is stable during install and everything works fine. Arch Linux is stable with gnome GUI.
I cant get windows or ubuntu to work. Fresh installs from different USBs to different SSDs. I always have my PC hang up on me or crash after I log in (Usually after opening a browers (Firefox, Chrome, Explorer).
Usually Windows doesnt even recognize the Apps I have installed until like 5min after I logged in. Like chrome is just the default as if the image was missing. I have flashed the BIOS, Wiped all drives completly (Also switched around from MBR to GPT partitioning). But it isnt helping. Memtest runs okay until it gets to the Patterns and stuff and fails because to many Errors.
Specs:
Gigabyte Aorus B365M Elite
2x8GB RAM
1060 TI 6GB
Intel 9700KF
3 Different SSD Hard drives (2 connected over SATA one over M.2 (Sata) all in AHCI.
I have a feeling something within the Bootloader is corrupt or the Bios is. How can I fix this? How can I diagnose this any further to get a solution. I am able to run Live USB (Terminal) and gather info/logs of crash events if needed. I currently have windows installed but it is NOT Stable enough to run anything.
The Temps of the Hardware are all in normal Ranges (Less than 85C)
Specs:
2x8GB RAM
1060 TI 6GB
Intel 9700KF
