HELP: NVTV CAD, NTFS FILESYSTEM
G
Guest
Guest
Archived from groups: microsoft.public.windowsxp.hardware (More info?)
I buy a Pint of View NVTV card and I have a problem:
when I try to record video, Forceware Multimedia (the softwae bundled with
the card), splits large files into a lot of 4.2Gb files!! I use NTFS
filesystem... why this happend??
Thaks
> with the card), splits large files into a lot of 4.2Gb files!! I use
> NTFS filesystem... why this happend??
Settings in the software.
I know many such applications will not do over the 4.2GB without editing the
registry.
Google for the solution. Call the software manufacturer.
<- Shenan ->
The information is provided "as is", it is suggested you research for
yourself before you take any advice - you are the one ultimately
responsible for your actions/problems/solutions. Know what you are
getting into before you jump in with both feet.
