Help on First Gaming PC
Shopon13
29
Hey I am building my first gaming PC and I will not be overclocking. I need help on whether all my components are compatible with each other and whether for example the motherboard I am using with USB 3.0 will fit in my case properly?
Intel Core i5 4570 Quad Core (Haswell)
AMD Radeon HD 7950 3GB Graphics Card
Gigabyte H87M-HD3 Motherboard
8GB Corsair Vengenance DDR3 1600MHz RAM
500GB Western Digital Black Hard Drive
Fractal Design Core 1000 Series Micro ATX Case
Corsair Builder Series CXM 500W Modular 80 PLUS Bronze
Yeah, sorry I miscommunicated that. The usb 3.0 ports in the back will work normally. Those two boards are very closely matched. The only difference I really see is the Gigabyte one is slightly bigger, and has less audio ports.
http://www.newegg.com/Product/Productcompare.aspx?Submit=ENE&N=100007627%20600438202%20600315499%20600009017&IsNodeId=1&bop=And&CompareItemList=280%7C13-130-698%5E13-130-698-TS%2C13-128-616%5E13-128-616-06%23&percm=13-130-698%3A%24%24%24%24%24%24%24%3B13-128-616%3A%24%24%24%24%24%24%24
Here's a full comparison, I'd probably just go with whatever is cheaper
Thanks im sorry im new to this, this case does not have front usb 3 headers but can i use usb 3.0 on the back of the motherboard through the back of the case? and can you please tell me if there is any difference and which is better between the Gigabyte H87M-HD3 OR MSI H87M-G43 m-ATX? thank you so much
