[SOLVED] Help on first PC build
Good build, any reason why you're opting for X570 over B450 or X470? Equally, even lower models X570 would be fine.
Also you can save a little by shifting to an Intel 660p which will be just as good if not better depending on your application.
PCPartPicker Part List
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor ($194.00 @ Amazon)
CPU Cooler: Corsair H100i RGB PLATINUM 75 CFM Liquid CPU Cooler ($129.99 @ Best Buy)
Motherboard: Asus TUF GAMING X570-PLUS (WI-FI) ATX AM4 Motherboard ($179.99 @ Amazon)
Memory: Corsair Vengeance RGB Pro 16 GB (2 x 8 GB) DDR4-3200 Memory ($84.99 @ Corsair)
Storage: Intel 660p Series 1.02 TB M.2-2280 NVME Solid State Drive...
Storage: Intel 660p Series 1.02 TB M.2-2280 NVME Solid State Drive ($82.99 @ Newegg)
Video Card: Gigabyte Radeon RX 5700 XT 8 GB GAMING OC Video Card ($403.98 @ Newegg)
Case: NZXT H510 ATX Mid Tower Case ($69.98 @ Amazon)
Power Supply: Corsair RMx (2018) 650 W 80+ Gold Certified Fully Modular ATX Power Supply ($119.99 @ Corsair)
Total: $1265.91
Generated by PCPartPicker 2019-11-29 19:06 EST-0500
Just food for thought - as It's a perfectly good build as it is.
Reactions: Alexferro1
