Help - once set as a repeater 192.168.10.253 can not be accessed: need to hard reset it to change anything!
nyc499
Commendable
Jul 30, 2016
18
good day !
I have this WiFi device "FDG WiFi Extender, 300Mbps Mini Wi-Fi Range Extender Repeater/Signal Booster/WiFi Router/Wireless Access Point with External Antennas, Extends WiFi to Home & Alexa Devices "
https://www.amazon.com/Extender-Repeater-Wireless-External-Antennas/dp/B07C93BJ6K/ref=cm_cr_arp_d_product_top?ie=UTF8
I have this working as a repeater
I have set it up by finding Wireless-N connecting and going to 192.168.10.253
and placed it on a tree with a long extension cord
now that my WiFi password has changed - I need to update the settings but when I try to go to 192.168.10.253 nothing happens - just times out - like accessing any other random local IP
Chrome:
This site can’t be reached 192.168.10.253
took too long to respond.
from what I read
>"Repeater turns off the DHCP in repeater mode by default, which means it won’t automatically assign IP to equipments connecting to it. You have to connect your computer to Wireless-N Mini Repeater by RJ45 [OR HARD RESET IT]"
FOUND ON http://www.turobotdiy.com/index.php?main_page=faq_info&faqs_id=6
so the only way is for me to pull it down from a tree - and hard reset it?
maybe I can play around with my WiFi properties?
like manually setting "IP/Subnet mask/default gateway?"
must be some smart way of doing this VS pulling it from a tree and doing a hard reset with a pin :/
thank you ...
Reactions: brianmichaelsteck
great idea
but I can not access this routers admin page
I might try to do a scan
what IP range should I target?
thank you...
Latest posts
