[HELP] Overclocked my i7-4790k to 4.4 ghz on 1.13V
Mar 2, 2018
7
Hello, yesterday i posted about me using the oc genie option on my motherboard, well today i overclocked for the first time and i got 1.13V for 4.4ghz overclock on my i7 4790k with h110i water cooler. Please tell me if my temps are good, thanks! :)
ASUS REAL BENCH STRESS TEST
max 73c
CINEBENCH R15 CPU TEST
max 71C
THANKS FOR READING!!!
try x45 with same voltage, then test if stable push it to x46 reapeat until it cannot boot, then you raise the voltage up, it a long process, but knowing the 4790K. you can go x46 with 1.26 easily.
My first time overclocking, i was just wondering if my cpu temps from asus real bench and cinebench r15 were good or not
But yesterday, my v core was at 1.216 with 4.4 ghz, and i got 76C on Cinebench, so im guessing it will get hotter if i raise the voltage and cpu speed, right?
If you are a first timer then try venturing beyond 4.4 because as "The Paladin" said so, you're just at Intel Turbo Boost speed which the processor will clock itself to when needed.
