Help Overclocking Asus 7850 Direct CUII 2gb
cerbres_child
8
Hey guys I'm trying to overclock my Asus 7850, but I can't get it past 1050 mhz.
All over the web people seemed to have got to 1200 mhz.
My Specs:
i3 3225 Ivy Bridge
Asus P8-Z77-V-LK
OCZ Vertex 3 90gb
Toshiba Desktop HDD 2Tb
Asus HD 7850 Direct CU II 2gb
Coolmaster Extreme Power Plus 500W
Corsair Phantom 410
Any tips? Currently getting about 25.1 fps in on Heaven Benchmark. Score 632?
A week gone without anyones reply..??? Comeon guyz ???
OK, With out the power/ voltage increase your overclock mileage will be very short. Every Card/chip is differnet some clocks better others dont. Use MSI afterburner and increase 25mhz core clock and then another 25MHz. Memory 50MHz than another 50MHz so you will know your limit. Each time Play very high quality games for few hours see if it last. Run Vantage/ 3dmark etc. If fails give the power target voltage a little bump see what chane it brings ( if the volt / power slider goes to full doesnt mean all card can use that. ) This should give a better understanding of your particular cards overclocking capability. Thanks
