I read a couple of guides online and decided to try my hand at overclocking my CPU. I only have a Coolermaster Hyper 212 Evo, so I decided I would only attempt a modest overclock to start.
I disabled Cool n quiet mode, enabled CPU unlock and set the ratio limit(CPB ratio) to 22. I then increased the multiplier from 20 to 21. I rebooted and ran Prime95 for 10 minutes with no errors, and my CPU temps stayed around 41C.
I noticed in CPU-Z the multiplier was reading as 20.5 instead of 21 as I had set it. But ignoring this, I increased the multiplier to 21.5 and tried again.
While running Prime95, my temps never exceeded 40C and I could see the load was constant 100% on all cores. I noticed the multiplier was flicking between 21.5 and 17 although the load was always at 100%. After about 2 minutes, Prime95 crashed. I started it again and within a minute the whole machine crashed.
Here is a picture of my settings:
BIOS
I'm pretty sure I should be stable at just 4.3GHz without touching voltage or anything, and my temps aren't even going high. What should I do?
By the way, mobo is a GA 990FXA-UD3 Rev 4
BIOS
