ok so im a computer geek on a extreamly tight budget. i started with an a6 pc i found in the trash, found a couple more crap pcs over time and was able to get 1x 4gb stick of ram and 3x 2 gb sticks of ram for 10 gb of ram. just got my friends old cpu after he upgraded so now i have a fx 6300. i broke down and bought the gigabyte 970a-DS3P FX to go with it along with an akasa venom voodoo cpu cooler.its got 6 copper heat pipes and i beliveve its rated for 200 watt heat displacement or w/e.i also have 5 140mm fans in the box i built to make a desk pc. so air flow is awsome. id say all the air in the case is pushed in and sucked out in under a sec.with a smoke test it fills my box and emptys it in about a second. i want to get every bit of performance outta the cpu and am wondering what settings i should change and to what to get best oc performance outta it. any and all imput is appreciated! tnx for the help in advance
