Fraga500 :
Thanks for the quick reply, rhysiam.
Was running at 1.3 but now switched to 1.27. Should I lower the voltage even more? Ratio is at 34 (125MHz).
Should I keep testing? Is it safe to keep reaching 92°C peaks (CPU Core 3) when running the test for 15 minutes?
What should I tinker with to lower these peaks?
Thanks
92C is still too high really. It is a stress test, so approaching worst-case scenario, but that's still too high.
In terms of addressing it, do you understand what voltage does?
Obviously higher frequencies mean the processor is running faster = better performance. So you want your frequency as high as possible.
BUT, once the frequency gets too high, the transistors in the processor can't change state quickly enough and the system becomes unstable (tests fail, bluescreen/crashes/lockups, etc).
SO, if you want that frequency to be stable, you need to raise the voltage. Raising voltage effectively pulls the transistors to the correct state faster, making it possible to keep a stable system at higher frequencies.
The problem is that raising the voltage increases heat substantially. This is often misunderstood. Raising or lowering the
frequency has a small impact on temperatures, but it's the
voltage that has by far the bigger impact.
Your 5820K is a quite a power hungry (=hot) CPU, and you have a fairly entry level cooling solution. It's not surprising you're hitting thermal limits.
So back to your situation... you've already gone past the point Linus is talking about in his video. The CPU is too hot, which means the voltage is already too high.
Here's what I suggest, just do the procedure backwards...
What you need to do is lower the voltage and keep testing. Try ~1.22. Hopefully that will put your temps back into the safe zone. BUT, you need to see if your current frequency is still stable at the low voltage.
If NOT - you can either raise the voltage a little again (if you have some headroom on temperature, as in you're back under 80C), or you'll need to lower the frequency until it's stable.
The end goal you want is the highest possible frequency, with the lowest possible voltage (while still being stable), with temps under control.
And, just to reiterate, the two key levers you have to work with are:
Frequency gives you speed, but higher frequencies become unstable without higher voltages
Voltage increases stability, making it possible to hit higher frequencies, but at the cost of additional power and thus higher temperatures.
