G
Guest
Guest
Archived from groups: alt.comp.hardware,alt.comp.hardware.homebuilt,microsoft.public.windowsxp.general,microsoft.public.windowsxp.hardware (More info?)
If it was running hot, most likely your CPU fan has failed,
reinstalling the OS does not fix the fan.
The people think the Constitution protects their rights;
But government sees it as an obstacle to be overcome.
"Bobby" <bobby@europe.com> wrote in message
news:2v6edbF2fksaiU1@uni-berlin.de...
|I did as one or two of you suggested and made the CD/DVD
drive a boot
| (master) device on its own channel (IDE1 - I left the HD
on IDE0).
| It booted from the Windows CD! I then installed XP SR1 and
then SP2.
| Everything was fine. Until this morning...
| It booted OK - but noticed that it was running hot (66-68C
once reached
| 70C - under no stress beyond Internet browsing). Then... a
reset and back to
| "Boot from CD:" and a hang! I couldn't believe it.
| So I'm back to square one. And the mobos going back to the
shop - along with
| the CPU. I've read of Prescott's running hot and this rig
seems jinxed.
| Bobby
| news:2v200qF2cn0e7U1@uni-berlin.de...
| > I've had hardware problems on-and-off for some time now.
So I took the
| > plunge today and replaced my Athlon 2000 system with a
new Pentium
| > (Prescot) system.
| > I bought a new motherboard (Abit), processor (Prescot P4
at 3GHz) and
| > memory (512Mb of DDR3200).
| > I managed to install the new mobo, CPU and memory
without problems (I've
| > done a few). But I have problems...
| > My PC reaches the POST OK and everything checks OK (I
can also access the
| > BIOS) but then nothing.
| > Windows XP (SP2) tries to boot but the system resets
when I reach the
| > Windows logo.
| > I tried to boot from CD (to re-install Windows) but the
PC hangs when I
| > get the message: "Boot from CD:".
| > One strange thing. The first message I get is:
"Verifying DMI pool
| > data..." and some times I get "success" and other times
I get nothing
| > before it tries to boot from CD (and fails). Is this
normal?
| > Help! I've tried everything including resetting the
BIOS. I've checked all
| > of the cables too. Everything seems to be fine - but the
damn thing will
| > not boot.
| > BTW I have two lights on the mobo - a green one when a
power cable is
| > connected and a red one (according to the manual this
simply means that my
| > system is switched on). Should this LED be red or green?
| > Thanks in anticipation.
| > Bobby
drive a boot
on IDE0).
then SP2.
once reached
reset and back to
shop - along with
seems jinxed.
| Bobby
So I took the
new Pentium
| > (Prescot) system.
at 3GHz) and
can also access the
when I reach the
| > Windows logo.
PC hangs when I
"Verifying DMI pool
I get nothing
normal?
damn thing will
| > not boot.
power cable is
| > Bobby
