Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
Greetings folks
1st of all, relevant system specs:
Asus P5GD2 Premium mobo rev1.14
Intel P550 J cpu
2 x Crucial/Micron 512mb DDR2-533 sticks (part no. MT8HTF64AY-53EA1)
Powercolor ATI X800XL PCI-X graphics card
Qtechnology QT-03460G 460W PSU
3 X Acoustifan AF80C 8cm case fans (12V / .12A each)
Lian Li PC-7 alu case
Building a new system and got my brand new Asus P5GD2 Premium a few
days ago. Anyway, my problem is that it won't boot past POST. I get a
single short beep and then it shuts itself down. At 1st I suspected
bad ram or it being the wrong spec, since Asus specifies double sided
ram from 512mb upwards for this mobo. However, after some searching on
the web I gather from Asus that any bios revisions prior to v1005 will
not boot with a P550 J cpu. My monitor screen is getting a signal of
only a few seconds before the system shuts down (too fast to read any
info) but I managed to grab a pic of this short lived screen with my
digi cam and the info I managed to get is:
"ASUS P5GD2 Premium ACPI BIOS revision 1003
CPU : Intel(R) Pentium(R) 4 CPU 3.40Ghz
Speed : 3.40 Ghz
Press F8 for BBS POPUP
PC2-4300 Dual Channel Interleaved
Checking NVRAM..
Initializing USB Controllers .. Done.
1024MB OK"
Very shortly afterwards it shuts itself down. My conclusion so far is
that I've got an old bios revision that's incompatible with the P500 J
series.
Further, the mobo revision is v1.14. I saw somewhere that this mobo is
now shipping as v2.0. Can anyone tell me what mobo revision they have
or what the latest current revision is?
So, did I get a motherboard that's been lying on the vendor's shelf
for at least 8 months? After all, that bios 1003 version dates back to
at least June last year. I can't get through to the vendor's tech
support hotline as it seems to be engaged all the time.
Asus UK expressly state they will not respond to technical queries and
that the online tech support form has to be used. I did this 2 days
ago but no reply as yet.
For those of you suggesting it could be a PSU problem, I already tried
that. My PSU supplies enough amps through the 12V line and, besides, I
have a 20 to 24pin ATX converter so that I can plug that into the
24pin ATX power socket on the mobo.
No, I definitely suspect the old bios not being compatible with the
P550 J cpu. I've got hold of v1008, the latest available from Asus but
how can I flash the bios if the *expletive deleted* system shuts
itself down a 10 seconds or so after switch on?
This problem is driving me mad and I've never come across this before
with the previous systems I've built. Does anyone have any helpful
suggestions? No, I'm not going to get another cpu (the non J version)
just in order to be able to flash my mobo.
TIA and cheers
Roger
Greetings folks
Intel P550 J cpu
Speed : 3.40 Ghz
Checking NVRAM..
1024MB OK"
series.
TIA and cheers
Roger
