i5 7600, Asus z270-a mobo and coolermaster master liquid 120 rgbWe need more information. Full specs are helpful, especially, in this case, CPU, GPU, and motherboard. Did you make sure everything was plugged in?
yellowAre any of the error LEDs lit? They are to the right of the RAM. Green, white, yellow or red?
That means there's a RAM error. Reseat the RAM sticks. If it still doesn't work, try with only one installed (try all independently.) Also try them in different slots.yellow
Thanks! i swapped the rams in my slots (after one appeared dead) and now it runs smoothly (the ram was just lazy or something now it works!)That means there's a RAM error. Reseat the RAM sticks. If it still doesn't work, try with only one installed (try all independently.) Also try them in different slots.
