Question Help pick out a case
Oct 21, 2019
12
Hi guys,
I'm looking to buy a new PC case for an ASUS TUF B365 mobo.
Currently have a Raidmax Ninja/Monster II which is really cramped in terms of room and cooling (got it when I was strapped for cash)
I'm looking at the below options
Antec P101 Silent https://www.antec.com/product/case/p101-silent.php
Corsair iCUE 220T RGB https://www.corsair.com/eu/en/Categ...ed-Glass-Mid-Tower-Smart-Case/p/CC-9011173-WW
NZXT H500 https://www.nzxt.com/products/h500-matte-white
I am going towards the Antec since it has better airflow and noise management but it has no tempered glass panel which I would have preferred. So would like some opinions on this.
Thank you
Hi guys,
Thank you
You're really going to have to pick between airflow and noise control, if you're dealing with overclocking or higher temperatures I would advise you go for airflow focus as fan curve profiles can compensate for noise
If you're running at stock settings and your temperatures are optimal you could emphasize sound dampening
Curious what components you'll be using as they'll generating your noise and heat. Cpu? Gpu? PSU? Cooling solution?
