Help picking the parts
ModernPanda
8
So I am building a gaming pc around £600-£650 [Ryzen build] but I am scared that the motherboard will not work with the ryzen 5 and i will have to get the ryzen 7 to update bios and need help with ram [speed and like that will it work with the ryzen cpu ] last thing is the gpu wht gpu should I get looking for 1080p gaming and high/ultra settings [GTA 5,BF1,CSGO,NEED FOR SPEED,ect..
This is my Build : Click here or https://uk.pcpartpicker.com/list/VCQ9m8
The board supports the entire Ryzen line, so a Ryzen 5 will be fine.
The memory should work.
Generally for 1080p 60Hz, you should be looking at a GTX1060 for high/ultra. If you had a higher frame rate monitor you could go for a 1070, and if you only wanted medium settings then a 1050Ti. I think you've made a good choice in the build.
One note: You have a micro-ATX board and a mid-ATX case. These are compatible, however you can fit a larger board in the case or you could fit your build into a smaller case. Essentially you're wasting space and I suspect it's because you've chosen the cheapest board you could find. Mid-ATX cases fit ATX boards.
I just had a look and I found a Gigabyte Nvidia GTX 1060 Xtreme 6GB GDDR5 for £286.76 + Rocket League for free but it says [This item has not yet been released.]
Frequency - 1,873 MHz
GPU Clock Speed - 1,620 MHz
Plus can u link me a mobo around same price and in the colour of black/red & and 1080p gpu to run games at high/ultra for around £280ish
