Help please :),BTX power supply to a micro ATX motherboard will it fit?
Eritz
i currently have an ATX power supply and want to change it with a BTX.
My motherboard is g41m-es2l (http://icecat.us/en/p/gigabyte/g41m-es2l/motherboards-G41M-ES2L-3535267.html) and supports micro ATX.
If i buy the BTX power supply will i it fit?
what i want to get (money is limited) (http://www.axd.gr/product_info.php?products_id=19427&osCsid=fbeequ8m8ltljo5epqa2pjrqi7)
(sorry for any bad english it isn't my mother tongue)
Hi - I believe that PSU is an ATX PSU, the BTX is just part of the model #. If you are able to get the dimensions,
post them here. In either case it will connect to the motherboard, it's the case you need to be concerned with the PSU fitting.
I think you are going to be OK, but get the PSU dimensions to be...
I think you are going to be OK, but get the PSU dimensions to be safe. The height and width on
ATX PSU's are std., only the length can differ, so unless you have a very small case, the PSU should
fit without any problem.
Hi again - The PSU is prob BTX after all, I don't think they would make it part of the model # if it wasn't BTX form
factor. However, it will still boil down to the size of your case (should not be an issue with the motherboard).
Personally, I would stay with an ATX PSU if I could afford to. With the BTX you might even have a problem
connecting it to the back of the case (the holes for the screws might not match up).
my case is midi tower
