Computer specs:
CPU: AMD Ryzen™ 7 5700G 3.8GHz W/ Radeon Vega Graphics
FAN: MasterLiquid Lite 120mm ARGB CPU Liquid Cooler with Dual Chamber Pump & Copper Cold Plate
VIDEO: GeForce RTX™ 3070 8GB GDDR6
MEMORY: 32GB (8GBx4) DDR4/3200MHz Dual Channel
MOTHERBOARD: (new MSI b450 tomahawk max)
(old ASRock B550M-C Micro ATX)
POWER SUPPLY: 750w
one day my computer wouldn't turn on. No lights, no power, no nothin. My first thought was power supply so I upgraded it to 750w from 600w, got a tester with the new power supply and both work fine. Picked up a motherboard from a friend for free that has never been taken out of the box. Moved everything over to the new motherboard and now all the lights and fans turn on but 0 display comes through. New motherboard has MSI EZdebug light and the CPU light is illuminated. The only cord that could not be connected to the motherboard is the RGB lights for the water pump. I built my first PC but with this one decided to go with CyberPowerPC, so I have some PC building experience but not a whole lot. I am at a total loss now and my brain hurts trying to do more research. I used PC part picker to check compatibility with the new motherboard and it said might have some issues, may need to update BIOS.
TRIED: replacing power supply, replacing motherboard, updating BIOS with FLASH BIOS stick using two different USB sticks and two different BIOS versions, unplugging graphics card to see if I could get the PC to turn on using integrated graphics in CPU (I don't know how to do this so i feel this option could be explored more), buying new ram sticks putting them in all configurations (2, 24, 13, 1234, 1, 3, 4)
I'm very close to jumping off of a bridge with my PC to send a messege to it.
POWER SUPPLY: 750w
