Question Help please !!! Latencymon & Lag issue
Aug 6, 2019
I just brought new PC then I installed windows 10 but I've heard it stutter when I play music, games and movies. I can feel spike lag just milisecond when I've move mouse. This spike lag happen every 1 or 2 minute.
Hoping you guys can help me out. T T
CPU: AMD Ryzen 7 3700x
Board: Asrock B450 steel legend
SSD:Lexar 250gB
HHD:WD 4TB
Ram: 32gb
GPU: Powercolor 5700XT
Windows 10 64x
Important drivers installed.
So I've searched the internet and already try tons of fix.
These are the list that I've done.
  • Turn off ‘Updates from more than one place’
  • Disable all start up apps
  • "Processor Power Management>Minimum Processor State>Change this setting to "100%."
  • "System Cooling Policy" set to "Active."
  • BIOS, disable "Cool'n'Quiet."
-Disable windows security notification icon
Here are the results:
_
CONCLUSION
_
Your system appears to be having trouble handling real-time audio and other tasks. You are likely to experience buffer underruns appearing as drop outs, clicks or pops. One or more DPC routines that belong to a driver running in your system appear to be executing for too long. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for 0:09:44 (h🇲🇲ss) on all processors.
_
SYSTEM INFORMATION
_
Computer name: DESKTOP-3U0LO5I
OS version: Windows 10 , 10.0, version 1903, build: 18362 (x64)
Hardware: ASRock, B450M Steel Legend
CPU: AuthenticAMD AMD Ryzen 7 3700X 8-Core Processor
Logical processors: 16
Processor groups: 1
RAM: 32699 MB total
_
CPU SPEED
_
Reported CPU speed: 3593 MHz
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
WARNING: the CPU speed that was measured is only a fraction of the CPU speed reported. Your CPUs may be throttled back due to variable speed settings and thermal issues. It is suggested that you run a utility which reports your actual CPU frequency and temperature.
_
MEASURED INTERRUPT TO USER PROCESS LATENCIES
_
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs): 3343.0
Average measured interrupt to process latency (µs): 4.837775
Highest measured interrupt to DPC latency (µs): 3289.90
Average measured interrupt to DPC latency (µs): 2.684458
_
REPORTED ISRs
_
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs): 14.367938
Driver with highest ISR routine execution time: Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Highest reported total ISR routine time (%): 0.000447
Driver with highest ISR total time: Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Total time spent in ISRs (%) 0.000447
ISR count (execution time <250 µs): 74098
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-999 µs): 0
ISR count (execution time 1000-1999 µs): 0
ISR count (execution time 2000-3999 µs): 0
ISR count (execution time >=4000 µs): 0
_
REPORTED DPCs
_
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs): 3303.954356
Driver with highest DPC routine execution time: ntoskrnl.exe - NT Kernel & System, Microsoft Corporation
Highest reported total DPC routine time (%): 0.004897
Driver with highest DPC total execution time: Wdf01000.sys - Kernel Mode Driver Framework Runtime, Microsoft Corporation
Total time spent in DPCs (%) 0.009065
DPC count (execution time <250 µs): 217797
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-999 µs): 36
DPC count (execution time 1000-1999 µs): 0
DPC count (execution time 2000-3999 µs): 2
DPC count (execution time >=4000 µs): 0
_
REPORTED HARD PAGEFAULTS
_
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in dropouts, clicks and pops. Check the Processes tab to see which programs were hit.
Process with highest pagefault count: radeonsettings.exe
Total number of hard pagefaults 3947
Hard pagefault count of hardest hit process: 790
Number of processes hit: 39
_
PER CPU DATA
_
CPU 0 Interrupt cycle time (s): 3.452527
CPU 0 ISR highest execution time (µs): 14.367938
CPU 0 ISR total execution time (s): 0.036523
CPU 0 ISR count: 65491
CPU 0 DPC highest execution time (µs): 3303.954356
CPU 0 DPC total execution time (s): 0.808331
CPU 0 DPC count: 207246
_
CPU 1 Interrupt cycle time (s): 3.030014
CPU 1 ISR highest execution time (µs): 0.0
CPU 1 ISR total execution time (s): 0.0
CPU 1 ISR count: 0
CPU 1 DPC highest execution time (µs): 338.848873
CPU 1 DPC total execution time (s): 0.007964
CPU 1 DPC count: 1307
_
CPU 2 Interrupt cycle time (s): 0.478166
CPU 2 ISR highest execution time (µs): 0.0
CPU 2 ISR total execution time (s): 0.0
CPU 2 ISR count: 0
CPU 2 DPC highest execution time (µs): 323.829669
CPU 2 DPC total execution time (s): 0.006281
CPU 2 DPC count: 2763
_
CPU 3 Interrupt cycle time (s): 0.526585
CPU 3 ISR highest execution time (µs): 0.0
CPU 3 ISR total execution time (s): 0.0
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 6.773170
CPU 3 DPC total execution time (s): 0.000074
CPU 3 DPC count: 55
_
CPU 4 Interrupt cycle time (s): 0.471123
CPU 4 ISR highest execution time (µs): 0.0
CPU 4 ISR total execution time (s): 0.0
CPU 4 ISR count: 0
CPU 4 DPC highest execution time (µs): 248.242694
CPU 4 DPC total execution time (s): 0.003247
CPU 4 DPC count: 1014
_
CPU 5 Interrupt cycle time (s): 0.535905
CPU 5 ISR highest execution time (µs): 0.0
CPU 5 ISR total execution time (s): 0.0
CPU 5 ISR count: 0
CPU 5 DPC highest execution time (µs): 16.211522
CPU 5 DPC total execution time (s): 0.000316
CPU 5 DPC count: 117
_
CPU 6 Interrupt cycle time (s): 0.472846
CPU 6 ISR highest execution time (µs): 0.0
CPU 6 ISR total execution time (s): 0.0
CPU 6 ISR count: 0
CPU 6 DPC highest execution time (µs): 252.370721
CPU 6 DPC total execution time (s): 0.005626
CPU 6 DPC count: 1224
_
CPU 7 Interrupt cycle time (s): 0.564371
CPU 7 ISR highest execution time (µs): 0.0
CPU 7 ISR total execution time (s): 0.0
CPU 7 ISR count: 0
CPU 7 DPC highest execution time (µs): 34.246591
CPU 7 DPC total execution time (s): 0.001532
CPU 7 DPC count: 476
_
CPU 8 Interrupt cycle time (s): 0.520558
CPU 8 ISR highest execution time (µs): 0.0
CPU 8 ISR total execution time (s): 0.0
CPU 8 ISR count: 0
CPU 8 DPC highest execution time (µs): 218.324520
CPU 8 DPC total execution time (s): 0.003979
CPU 8 DPC count: 942
_
CPU 9 Interrupt cycle time (s): 0.511195
CPU 9 ISR highest execution time (µs): 0.0
CPU 9 ISR total execution time (s): 0.0
CPU 9 ISR count: 0
CPU 9 DPC highest execution time (µs): 52.502087
CPU 9 DPC total execution time (s): 0.002067
CPU 9 DPC count: 606
_
CPU 10 Interrupt cycle time (s): 0.546553
CPU 10 ISR highest execution time (µs): 0.0
CPU 10 ISR total execution time (s): 0.0
CPU 10 ISR count: 0
CPU 10 DPC highest execution time (µs): 462.509324
CPU 10 DPC total execution time (s): 0.003177
CPU 10 DPC count: 598
_
CPU 11 Interrupt cycle time (s): 0.498158
CPU 11 ISR highest execution time (µs): 0.0
CPU 11 ISR total execution time (s): 0.0
CPU 11 ISR count: 0
CPU 11 DPC highest execution time (µs): 83.271918
CPU 11 DPC total execution time (s): 0.001672
CPU 11 DPC count: 553
_
CPU 12 Interrupt cycle time (s): 0.568533
CPU 12 ISR highest execution time (µs): 3.857501
CPU 12 ISR total execution time (s): 0.000890
CPU 12 ISR count: 1611
CPU 12 DPC highest execution time (µs): 24.387420
CPU 12 DPC total execution time (s): 0.001384
CPU 12 DPC count: 315
_
CPU 13 Interrupt cycle time (s): 0.504768
CPU 13 ISR highest execution time (µs): 1.472864
CPU 13 ISR total execution time (s): 0.000071
CPU 13 ISR count: 119
CPU 13 DPC highest execution time (µs): 69.575285
CPU 13 DPC total execution time (s): 0.000503
CPU 13 DPC count: 104
_
CPU 14 Interrupt cycle time (s): 0.545570
CPU 14 ISR highest execution time (µs): 3.366546
CPU 14 ISR total execution time (s): 0.000770
CPU 14 ISR count: 1726
CPU 14 DPC highest execution time (µs): 70.887837
CPU 14 DPC total execution time (s): 0.00120
CPU 14 DPC count: 302
_
CPU 15 Interrupt cycle time (s): 0.640388
CPU 15 ISR highest execution time (µs): 3.426663
CPU 15 ISR total execution time (s): 0.003618
CPU 15 ISR count: 5151
CPU 15 DPC highest execution time (µs): 32.503201
CPU 15 DPC total execution time (s): 0.000938
CPU 15 DPC count: 213
Here is image!!
https://ibb.co/j6623cy
