ok i will make this short my sister somehow gave me back the flash but it won't work when i plug it in it asks for format but it won't format, Tries...
Diskpart trying to clean or create partition or anything : the system cannot find the file specified please check the system log "can't find the error in the event viewer though"
EaseUS cannot create partition....
same as darkwizard
I can see the usb on disk management...
Tried Phison mptool as it was recommened by chipgenius said driver not found....
Chip Genius details :
Description: [H:]USB Mass Storage Device(Kingston DataTraveler 2.0)
Device Type: Mass Storage Device
Protocal Version: USB 2.00
Current Speed: High Speed
Max Current: 100mA
USB Device ID: VID = 0951 PID = 1665
Serial Number: 1C6F654E3F31FE3139307DB5
Device Vendor: Kingston
Device Name: DataTraveler 2.0
Device Revision: 0100
Manufacturer: Kingston
Product Model: DataTraveler 2.0
Product Revision: 1.00
Controller Vendor: Solid State Systems
Controller Part-Number: SSS6698-BB
Flash ID code: ADDE94DA - Hynix H27UCG8T2ATR - 2CE/Single Channel [MLC-8K] -> Total Capacity = 16GB
Tools on web: http://dl.mydigit.net/special/up/sss.html
same as darkwizard
Max Current: 100mA
