php09sk
I am planning to build a new system and my main purpose is for photo/video editing(photoshop, light room...). Can you please comment on the configuration
Intel i5 3750k or i5 3450
ASRock Z77 Pro4 or AsRock H77
16GB-Kit Corsair Vengeance schwarz PC3-12800U CL9-9-9-24
EVGA GeForce GTX 650 Ti SSC, 2048MB DDR5, PCI-Express
be quiet! Pure Power L7 530 Watt
Seagate Barracuda 7200 2000GB, SATA 6Gb/s
any comments/suggestions are appreciated
Cheers,
Sun
MylesMPC
53
Looks pretty good! Everything should work. I would go for the 3570k and overclock it if you can. If you do that, you might want a 600w PSU, and better cooling. Other than that, you are all set!
popatim
You need more harddrives for efficient video processing. Its suggested 3 minimum and 4 optimal.
3 drives: OS/Programs/Source, Scratch, Destination
4 drives: OS, Source & programs, scratch, destination
Up to 32gb ram.
Also an AMD GPU if you plan on using GPU processing as Abode has dropped cuda support with CS6 in favor of opengl and amd's just kick arse in that department. Which also places more emphasis on making your hdd systems as fast as possible.
I suggest you read up on whats optimal for drives in your favorite editing forums.
