Help preventing XP Pro running file check on boot
byanoseau
8
Hi Everyone,
Would someone please tell me how to prevent XP Pro running a file integrity check every time the computer boots?
I Have 3 HDD's in the computer, two of which are Fat32 (Primary Master C: and Primary Slave D:). The other drive is NTFS ( Secondary Master E:) It's the secondary master E: drive that checks the file integrity every time the computer boots.
Thanks.
Byn
I am sure you already tried the list below but asking anyway just incase you did not.
Did you let it finish, usually if you let finish running it won't run anymore after that? Does it ask you to hit esc key to cancel the scandisk? Hard drive going out?
😎 <font color=blue> I know nothing that is why i am here at THG!</font color=blue>
Hi juice,
Thanks for the reply. I've let it run until it finishes, and yes, there's an option to cancel, which I now do. The HDD in question is a new one.
Do you have any more suggestions I might try?
Thanks.
Byn
Is hard drive still running check disk after you bounce the computer?
Check your event logs and see what error msg. there might be. Repost with your findings.
re: "I've let it run until it finishes"
Use this tool at the command line:
<A HREF="http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/chkntfs.mspx" target="_new">Chkntfs</A>
Toey
<A HREF="http://forums.btvillarin.com/index.php?act=ST&f=41&t=328&s=91c282f2e5207e99b7a652ee13b3512a" target="_new"><font color=green>My System Rigs</font color=green></A>
_______________________________________________
<A HREF="http://forums.btvillarin.com/" target="_new"><b><font color=purple>BTVILLARIN.com</font color=purple></b></A> - <i><font color=orange>Your Computer Questions Answered</font color=orange></i>
Thanks for that tip! Always learning something new here.
