Help! problem updating bios on z170a krait gaming.
JasonTechGamer
50
Hi guys, so currently i have the z170a krait gaming along with an i3 6100. So ive heard about the new skylake non k oc bios so i decided to look it up and found e7984.b5t file which is for my motherboard. However after putting the file into a usb flash frive (fat32) and entered m-flash, the bios wont recognize the file. Anyhelp!? Thanks for your time.
Well i see the file from one drive is zipped so you unzipped it with winrar or 7 zip or something before you used it right? It wont work if you didn't. Beyond that im not sure I just looked in the manuel of your mobo it seems like a very simple process it should just detect it. Are you sure your using the right one? The one for your mobo is E7984IMS.B5T.
