HELP!Problem with cpu temperatures..
aggelos123
254
hello..4 days ago i builted my first gaming pc.
i downloaded hwmonitor and the cpu temp was (in idle) about 40C...i was like wtf a new system cant have 40C in idle and when i am browsing it shows about 55C!(i have the stock cooler that came with my cpu..amd athlon x4 750k)i installed a program that came with my mobo(gigabyte f2a88xm-hd3) which is called easy tune 6 and it showed idle temp of 21C...i dont know what is going on...i downloaded another program (AIDA64) and it showed the same temp with easy tune 6...i dont know which program is telling the truth..:/...can you help me?btw the BIOS cpu temp when i start the pc is about 35C...which program should i trust please help me!i downloaded real temp and core temp and they didnt show my temp..
it was a budget built...so 21C that easy tune 6 and AIDA64 shows is not the true temp?while i am gaming these 2 programs are showing 40c temp...
Those programs are really bad, i am also guessing you misread tempratures in Aida and are reffering to a cores temprature.
Go with realtemp and HWmonitor, i only use realtemp and bios. Once you are gaming and minimize the game you cant ussualy see the temprature it is, you can however log it with realtemp.
PS: check out my links in my edited post (previous one).
Latest posts
