Okay here is the problem...
My copmuter cycles the power...want better explanation here you go....
I plug in my power supply, hit the power button, I see my copmuter light up for half second, then turns off. 🙁 BUT it turns back on....then off...then repeats the same thing over and over again.... I shall post all the parts I used.... PLease Help Me....
MAIN PARTS:
GIGABYTE GA-P55A-UD3 LGA 1156 Intel P55 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128412
Intel Core i5-655K Clarkdale 3.2GHz 4MB L3 Cache LGA 1156 73W Dual-Core Unlocked Desktop Processor BX80616I5655K
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116369
GIGABYTE GV-N460OC-768I GeForce GTX 460 (Fermi) 768MB 192-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814125334
LG WH10LS30K 10X Blu-ray Burner - LightScribe Support - Bulk - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103046
COOLER MASTER Intel Core i5 compatible GeminII S RR-CCH-PBU1-GP 120mm Sleeve CPU Cooler
Antec Nine Hundred Two Black Steel ATX Mid Tower Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129058
CORSAIR CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
Western Digital Caviar Blue WD6400AAKS 640GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136218
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL8D-4GBRM
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231275
FANS:
APEVIA CF12SL-UBL 120mm Blue LED Case Fan
http://www.newegg.com/Product/Product.aspx?Item=N82E16811998121
MASSCOOL BLD-12025V1 120mm Blue LED Case Fan
http://www.newegg.com/Product/Product.aspx?Item=N82E16835150115
THanks Again!!! 🙁
MAIN PARTS:
FANS:
THanks Again!!! 🙁
