Help put in a new Gigabyte GEFORCE gtx 750TI and computer is stuck at start up and it beeps once every 30 seconds then after..
Bryson Scott
35
2 mins or so it beeps once then twice really fast then the monitor goes black please help!!!
Current pc spece
Hp p6755a
corsair CX600M watt psu
gpu^^^
10gb ram
intel i5
Need help asap!!! whoever solves this i will give 50 dollars each for 2 ingame purchases
Its an OEM computer. The manufacturer might have set it up to not allow installation of aftermarket devices like a new graphics card.
Remove the 750Ti, put back the old card (if it had one) and try to boot again. If it works you might want to first uninstall the old graphics drivers, before trying to switch the card again.
And in case you didn't know, have only one graphics card installed. Having multiple cards can cause problems.
1. i can run my friends 680 perfectly and 2 i have uninstalled the drivers
i dont have a friend atm and can you explain why the pc beeps like once every 30 secs 4-5 times then beeps once long then 2 really quick then the monitor goes black? and it shouldnt be faulty i got it today!
Your PC is beeping and not booting because of hardware failure or incompatibility. Your card may be new but that does't mean its not damaged or defective.
Since your 750Ti is the only change in hardware I suspect it is the cause of the problem, which is why you should test if it is working. If it is a bad or dead card you want to get it replaced asap.
i just downloaded a bios update will this fix the problem?
