Build Advice Help putting this PC together and will it work ?
Elliah246
167
5
585
I'm asking for a friend who's asking for a friend who's asking for a friend, crazy i know. But here i am.
Specs are as follows:
CPU • AMD Ryzen 7 9800X3D
GPU • AMD Radeon RX 7900 XTX
Board • ASUS ROG Strix X870E-E or ASUS ROG Strix B850-E
Can't make up my mind which board to take, would be so nice if you can help me out... pros/cons? The most expensive option isn't always the best.
PSU • BE QUIET! Dark Power Pro 13 1300W
I've read bad reviews about this power supply like explosions or disturbing noise, however the previous series (pro 12) sold out. Any titanium 80 plus alternatives?
Will 1000W be fine for this system?
Display • ASUS ROG Swift OLED PG27UCDM
This monitor is 4k, 240Hz and uses Displayport 2.0, can the AMD Radeon RX 7900 XTX graphics card even handle the UHBR 80 spec or should i wait for the next gen?
I want to avoid DSC.
Case • Corsair 4000D Airflow ATX Mid Tower
CPU Cooler • Arctic Liquid Freezer III 360
Keyboard • Any non RGB with fast responsetimes
Help me find one?
Mouse • Logitech G502 HERO
Memory/Ram • dual channel DDR5 2x16 GB or 2x32 GB
On AMD's website i couldn't find EXPO certified ram from corsair, is there any corsair ram that will work out well as dual memory channel with expo enabled?
Otherwise which brands can you recommend? From my understanding the ram should have a low CL number (low latency) and high MT/HZ.
What's the best DDR5 options with lowest CL combined with highest HZ? For example my current corsair vengeance runs at C16 combined with 3200MHz.
I can't find anything near C16 when it comes to DDR5. Your help is greatly appreciated.
You're advised to stylize your thread with info asked of in this thread;
and the community can chime in with worthwhile suggestions for your friend of a friend of a friend's PC.
if you're located in Europe, please specify your country to understand your currency and available brand and products availability. We will need a budget as in an amount of how much will be spent.
When it comes to the motherboard, what features on those boards are you seeing as desirable? $350 is a lot for a board. Only outstanding things I see are 5 m.2 slots and 5Gbps network and WiFi 7. Do you have a 5Gbps network to plug it into? Do you need 5 M.2 slots?
Can't really think of a slow keyboard out there. For gaming it is best to get a keyboard with N-Key rollover so that you can press lots of buttons at once. Beyond that I don't mind a decent Logitech carbon for a basic mechanical keyboard.
On the GPU / Display question, you are kind of stuck with what is available. Not very monitors are up to date and only the very latest GPUs support the latest standards. If you are going with a 7900XTX, not much else to say there, it has the ports it has. RTX 5080 if you want to be on the bleeding edge.
You aren't going to find CL16 DDR5, but the current consensus is CL30 6000MT/s or CL32 6400MT/s I have picked out a Corsair kit below with EXPO support. Equivalent would be CL15 3000 and CL16 3200 which were common speeds for DDR4. AMD doesn't really like to go any faster.
PCPartPicker Part List
CPU: AMD Ryzen 7 9800X3D 4.7 GHz 8-Core Processor ($479.00 @ Abt)
Motherboard: Asus TUF GAMING B650-E WIFI ATX AM5 Motherboard ($194.99 @ Newegg)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory ($96.99 @ Newegg)
Keyboard: Logitech G513 Carbon RGB Wired Gaming Keyboard ($129.99 @ Newegg)
Total: $900.97
Generated by PCPartPicker 2025-02-05 16:10 EST-0500
Reactions: ykmtx
Help me find one?
Knowing your location and budget would help us. Here's a 4K gaming build I posted yesterday that includes DDR5-6000 CL28, board w/PCIe 5 and Realtek 4080 audio codec, ATX 3.1 psu, etc ...
https://pcpartpicker.com/products/video-card/#c=587
RTX 5090 32GB
CPU: *AMD Ryzen 7 9800X3D 4.7 GHz 8-Core Processor ($479.00 @ Abt)
CPU Cooler: *ARCTIC Liquid Freezer III 360 A-RGB 48.82 CFM Liquid CPU Cooler ($107.79 @ Amazon)
Motherboard: *MSI MAG X870 TOMAHAWK WIFI ATX AM5 Motherboard ($279.99 @ Amazon)
Memory: *TEAMGROUP T-Force Delta RGB 32 GB (2 x 16 GB) DDR5-6000 CL28 Memory ($119.99 @ Newegg)
Storage: *Acer Predator GM7000 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive ($132.99 @ Amazon)
Case: *Lian Li LANCOOL 216 RGB ATX Mid Tower Case ($109.97 @ Amazon)
Power Supply: *MSI MAG A1250GL PCIE5 1250 W 80+ Gold Certified Fully Modular ATX Power Supply ($189.99 @ Amazon)
Total: $1419.72
*Lowest price parts chosen from parametric criteria
Generated by PCPartPicker 2025-02-05 17:24 EST-0500
View: https://www.youtube.com/watch?v=9TfR60pM5oU
View: https://www.youtube.com/watch?v=ykbhuv6yLBc
iu
I have the Asus Strix X870E paired with a 9800X3D. For the RAM I got 64 GB (2x32) Corsair 6000 MHz CL30 and it was not stable (looked ok at first but PC started rebooting by itself). So I changed the timing to CL32 and it has been working great since then. But I updated the BIOS a few days ago so maybe the new version is more stable at CL30. I might try it sometime, but according to some tests I have seen online the difference would be unnoticeable.
Reactions: Why_Me
Great!
Yes, location is europe, i'd rather keep my country private but will say i'm able to buy products from many european countries.
Budget is around 4000 euro, targeting a high end pc, however the most expensive is not always a good choice so when recommending products please keep that in mind^^
Total: $900.97
Totally agree, 350 is a whole lot of money for a board.
No, the 5 m.2 slots as well as the 5Gbps network and wifi7 aren't making sense to me.
Stability and performance are target, no need for an overkill product.
Two m.2 slots would be just fine.
Can the ROG Strix B850-E handle a graphics card and sound card at the same time while still running the GPU pcie 1x16 rather than 2x8 ? Or would be bandwidth be split into half?
Never heard about N-Key rollover.
How does this work in practice? Pressing many keys at the same moment sounds like a standard situation for any gaming pc?
While budget isn't an issue i dislike nvidia for many good reasons like paper launches, fake msrp and intentional price inflation, misleading performance claims and more.
Shoving cash down nvidias greedy throat isn't something i am interested to.
The only question is to buy the current amd flagship or wait for a future release, even when reports claim amd stepped down from producing high end gpus.
What about the 7900XTX, does it support UHBR 80 Gbps?
Thanks for recommending that ram to me, i found the
on the corsair website and to linked device code: CMK32GX5M2B6000C30
checking amd's expo certified ram list doesn't show any results for the above device code.
How did you figure out this ram is expo compatible?
Also there is CL28 corsair vengeance ram, why not get that rather than CL30 ?
RTX 5090 32GB
Total: $1419.72
I've already replied about location and budget^^
Could you specify realtek 4080 audio codec, what is it and why did you mention it?
Does PCIe 5 bring and significant improvements compared to PCIe 4?
What's the matter with ATX 3.1 power supplies?
Thank you, much appreciate the honesty.
Stability is a nr1 priority above all.
Would it make any difference if the ram was 2x16 or 2x32 GB in regards to stability / pc rebooting by itself? Or is that caused by the CL timing and HZ regardless of the amount of memory?
Edit:
To summarize, few things remain unanswered.
GPU • It should support DP 2.0 UHBR 80
Board • It should be around 200 euros, not because more exepsnive options aren't in the budget but because paying many hundred euros for a board is straight up BS.
Power supply • The BE QUIET Dark Power Pro 13 seems to tend to explode and make noise according to some customer reports, for those reasons i'm looking for a titanium 80 plus certified alternative.
Keyboard • Logitech G413 SE PBT seems alright since i am very much not a fan of wasting money for RGB, a decent mechanical gaming keyboard does the job, however the above product lights up the keys, question is if there is a way to permanently disable the key lights, disabling the lights after every boot is not a sane option.
Are you planning on a sound card? One of the reasons to seek out higher end boards is higher end audio solutions. Can't recall the last time I recommended an actual sound card that wasn't a break/fix. Most people beyond a certain audiophile level just switch to budget friendly USB DACs and use those instead.
Cheap keyboards might have a few key rollover. Older membrane keyboards are usually limited to one key press per section of the keyboard. N-key means you can press all the keys and still have them register to the system.
7900XTX supports 80Gbps via Display Port 2.1, HDMI, no, 4K 144hz would be the limit without DSC. With DSC 4K 240hz.
This is the memory part number I linked, it says EXPO on the marketing image and they list it on their website. There are some kits out there that support both, this is one of them.
CMK32GX5M2B6000Z30​
https://www.corsair.com/us/en/p/mem...z58Uks2LhU:iTlg3E0&utm_coupon=Content&irgwc=1
Generally, I just look them up individually. But there are a few that are known to me.
CL28 is fine if you can find it for a reasonable price.
I picked out a reasonable ASUS board that would get the job done. You could go cheaper or more expensive depending on if you are going after appearance or features.
Superflower Leadex is probably what I would pick out for a Titanium rated unit. But really I don't see much point in going above gold. Thermaltake Toughpower GF3 is a good unit. Seasonic Vertex. (I can't really justify the Seasonic Prime Titanium, just too much cost)
6-key rollover anti-ghosting on that one.
I hate to say that your typical gamer wants the RGB, so most of them have it. As to permanently disabling the lighting, you could surely disable it physically if you tried.
Also some higher end plain units, but the prices start to go up.
https://pcpartpicker.com/product/YFFPxr/das-keyboard-keyboard-dask4mkprosil
If you want to start getting specific with keyboards, you can look at custom models from the likes of Keychron and other custom suppliers, but be prepared to pay more than you would expect.
CMK32GX5M2B6000Z30​
https://www.corsair.com/us/en/p/memory/CMK32GX5M2B6000Z30/vengeance-32gb-2x16gb-ddr5-dram-6000mt-s-cl30-amd-expo-memory-black-cmk32gx5m2b6000z30?utm_source=79301&utm_medium=Affiliate&utm_campaign=497986_CORSAIR US Product Catalog Ad&utm_content=Corsair&clickid=wm70MlTzZxyKRLXVSZU7Kz58Uks2LhU:iTlg3E0&utm_coupon=Content&irgwc=1
Actually the sound card is already there.
Hmm. I've never had issues with any keyboard where the strokes where not recognized by the os.
Well in this case considering waiting for the next amd gpu release might be worth it.
240Hz without DSC would be great. Even tho some people argue the human eye can't differ between DSC and no DSC.
The CMK32GX5M2B6000Z30 does says AMD EXPO in it's title, yes.
But couldn't that be purely marketing from corsair? I would feel safer if the ram was listed on amds expo certified ram list which it isn't. Of course the ram might work fine with EXPO but there's risk involved or at least amd isn't officialy supporting it.
The CL28 version of the ram you sent also show up as AMD EXPO compatible on corsairs website, it is more expensive tho. Not sure if it's worth the price increase.
Found the CL30 for 108 euros and the CL28 for 131, so that's 23 euros more. Not a whole lot.
JayGau mentioned he had to change from CL30 to 32 because his system wasn't stable, i assume that could mean i'd have to go from 28 to 30 eventually.
The only appearance i care about is the visuals of the monitor, as for the rest all black without any rgb. The features i need from the board are two pcie slots one for the gpu, the other for the soundcard, possibly without splitting bandwidth from x16 to x8.... and 2x M.2 slots.
Other than that it should be stable, that's pretty much about it.
I've had a seasonic in the past and it failed me miserably, never buying this brand again.
Thanks for the other recommendations tho.
Is a 1000W PSU fine for the system i put together, or 1200W?
It's not a workstation, just gaming, streaming, browsing, videoediting, etc.
I'm aware of the RGB situation and the madness is causes to prices. Lucky me i don't like it at all.
Physically disabling, yeah i had that thought but i don't want to end up killing the keyboard.
I don't think 2x16 or 2x32 makes much difference. DDR5 is designed to work with high capacity. The clock speed and timing are really what matters (and if you have 4 sticks instead of 2, that would also be much more demanding on the controller so less stable). And the AM5 platform is well known to be picky with RAM timing, especially the X3D chips.
But it really depends on a combination of factors, like your board and RAM brand/model, your CPU, the BIOS version, etc. Maybe your setup will run great at 6000 MHz CL30 depending on how well the parts you chose work together, and of course, the silicon lottery that nobody can predict.
Parts are not much more expensive because of RGB, that's a myth. RGB versions usually cost a few bucks more than the non-RBG. And like anything else, you cannot know if you like it or not before you try it. I though I didn't care about RGB until I got some in my case and realized how cool it looks (when you take the time to set it right). Now I have plenty and feel good every time I turn on my computer and see how great it looks. Some say it's useless and a waste of money because it just anesthetic , and then go straight to the Call of Duty store to buy 80$ of skins. Yes visual can be important and it's a personnal choice, nothing to do with being "lucky" like it's some sort of disease you don't have.
I figured B650-E vs 850E are the most sane options, however the 850 is double the price and i'm not sure if it's worth it. I'm concerned now after reading that the B650 has problems with the intel lan controller, same goes for the X670 boards, can anyone confirm this? Would this be an argument to get the 850 instead or does that one have the same problems?
The power supplies that have been suggested to me, EVGA SuperNOVA T2, Thermaltake ToughPower GF3, Super Flower Leadex VII Platinum Pro, are unfortunately not really available in my area but the be quiet dark power pro 13 is very expensive and as i said i've read reports of explosions and disturbing noise. For such a high price i would expect a titanium certified PSU to not have any such problems.
Any more suggestions?
I just figured out something about my RAM and I think it's relevant here. I said in a previous comment that my RAM was not stable at 6000MHz CL30, but after reading more online, I got convinced that it should be. So I took a look at my order and turns out there was a mistake: I didn't pay enough attention and bought the kit optimized for XMP, but the thing is that AM5 requires more voltage to be stable at the same timing than Intel CPUs (but EXPO sets the voltage of my kit to 1.35 by default). So I set back my timing to CL30 and increased the DRAM voltage to 1.4V, which is the default voltage for Corsair "EXPO certified" kits. It has been running without any issues so far.
So be careful with that and make sure your voltage is set correctly, or get an EXPO certified kit, and you should be able to do at least CL30 6000 MHz and likely even better.
That's good to know, thanks
What do they mean by is USB gen 3.2 gen 2 used for power transmission? How do i tell?
Edit: thats the PSU calculator from be quiet, i still don't know if i should get a 1000W PSU for the system i described in my first post, or if it should be above 1000W.
They ask if you expect to use your USB 3.2 ports to power things, like charging phones or laptops. You should leave it to no, unless you expect to use your PC as a power house for your other devices.
By the way, 1000W is more than enough for THIS build, but the question is, do you expect to upgrade to more power hungry hardware in a near future? Like if you think you may get a 5090 at some point, 1000W is going to be a the very edge.
Would 850W do the job aswell? Say THIS system will be under full load while playing a very graphics intense photorealistic game with raytracing, how much of a 850W psu would be utilized?
Hm, to be honest i don't intend upgrading the system at all. I want to get a high end system, and stick to the rule never touch a running system. Paying for high end should equal a system lasting for around 10 years. The 5090 seems like a waste of money considering the minimal performance uplift compared to the 40 series. Not worth it. AMD does better with price-value.
I mentioned the 5090 as an example since it's by far the most power hungry card on the market. But who knows how it's going to be in 2 years.
It doesn't really matter what kind of games you expect to play. Your PSU has to provide enough power for your system to work at 100% load, otherwise you would have a lot problems. The 7900xtx is not as power hungry as the 4090, for example, but still requires a good amount of juice. 850W should be fine if you don't get an OC version, but some people say it's better to go with 1000W to have some extra headroom. But if you get an OC version (with 3x 8-pin connectors instead 2x), then you should definitely go with 1000W.
